clutch pushrod help
- jordan
clutch pushrod help
14 Feb 2008 13:44
As Im finishing up my motor build I am putting on the last few bits and bolts. I was going to place on my clutch cover today when I noticed there was just a hole in the block where the clutch arm mechanism would sit in front of. My first reaction was WTF!!! I went over to another one of my kz's and noticed a rod protruding from the black where the hole is. I have discovered that this rod is called the clutch pushrod. When I get one to put in, can it be done with no dissambly? I would hate to split the cases after I just finally got the motor together!
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
Re: clutch pushrod help
14 Feb 2008 13:54
did you comepletely dismantle the motor?there is a "pusher"i guess yu would call it that the pushrod pushs against inside the motor and a ball bearing that goes in between.as long as the pusher and ball bearing are installed you can put the rod in without splitting cases;)
- ronjones
14 Feb 2008 14:23
If this is on your 82750(twin?), then the ball bearing is installed on the clutch side. I'm pretty sure the plate pusher is on the clutch side also. Either way you shouldn't have to split the cases.
- jordan
14 Feb 2008 19:21
It is the 4 cylinder 750 motor for my streetfighter project. I never took apart the cases at all. Just happened to notice it was missing. If i pull the rod from another motor i have, does it just simply pull out? To reinstall it do you just simply push in the ball bearing, followed by the rod?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
14 Feb 2008 19:53
put some grease on the bearing and the rod push her in;)
- jordan
14 Feb 2008 22:05
thanks for savin me again KZR
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- kzwolfsr
15 Feb 2008 06:13
If you hadn't noticed that You would of never been able to disengage your clutch. lucky you!
Original man of the Caribbean
