Manual vs auto cam chain tenioners
- kzmason
puts your engine's fait in your hands, unlike the stock automatic tensioners that have a tendency to skip a beat when the throttle is closed suddenly at high rpm. This allows the cam to go momentarily out of time, and can result in bent valves and/or serious engine damage. Hydraulic style tensioners have furthermore a tendency to put too much tension on the chain guide under high rpm/high oil pressure conditions resulting in premature wear. Both problems can be eliminated with the installation of a manual tensioner.
APE says almost the same thing word for word.
Is it all true, or are they just scaring into buying them? I have the one from APE, but while adjusting it, EXTREME paranoia set in. Is it tight ENOUGH? Is it TOO TIGHT! Ahhhhhh! How the hell do you know when the tension is just right?
Post edited by: kzmason, at: 2008/02/14 12:17
- PLUMMEN
- Thank you received: 104
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
The stock tensioner, over time, will tend to lose the "spring in it's step", and not remain as tight. The wedge self-adjuster doesn't stay tight, and is only working against a spring. Too tight isn't good, and too loose isn't either. Buy a new spring, or buy the manual tensioner. Just like the Harley and it's oil leaks, the Kawasaki in-line 4 is known for it's timing chain clatter at idle.
'85 GPz550(ZX550-A2)
- 79MKII
- Love Them Kaws!
- Thank you received: 43
The Kaw List:
- Jack
- Thank you received: 7
sh*t in your oil pan/filter. Ask me how I know that ....
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- RonKZ650
- Thank you received: 240
- Bluemeanie
- Thank you received: 14
- kzmason
- 79MKII
- Love Them Kaws!
The Kaw List:
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- 79MKII
- Love Them Kaws!
The Kaw List:
- 79MKII
- Love Them Kaws!
Maybe I'll go back to my converted stocker...
The Kaw List:
