Well, That kinda Blows!
  • ran429
  • ran429's Avatar Topic Author
  • Master of FREE rides!
13 Feb 2008 18:11
#194463
I just took the kz out for a spin for the first time in nearly a year.
I got it firing on all 4 and running like a raped ape, but that Head on the #1 cyl either got loosened or my Gasket needs replacing.
Seems i am getting oil blowing out of there which sucks because now i will have to plan on doing a head gasket soon, Never been into a motor before.
Hope its easy. :blink:
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Well, That kinda Blows!
13 Feb 2008 18:34
#194467
try retorquing head bolts first,couldnt hurt;)
  • The Milkman
  • The Milkman's Avatar
13 Feb 2008 18:47
#194471
Well Randy, as you know, that is enough help on here to get you through any dilema. ;) ;)
  • KZErider
  • KZErider's Avatar
13 Feb 2008 18:51
#194473
Sorry to hear that, Randy. I'm sure you'll get 'er straightened out before the "real" riding season gets here. Godd luck and hope it's an easy fix!
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
13 Feb 2008 19:31
#194481
DUCT-TAPE!!:woohoo:
Just kidding Randy...like the plummer said...try retorqueing the head bolts first...
1977 KZ1000 A-1
  • Mark Wing
  • Mark Wing's Avatar
13 Feb 2008 20:00
#194485
That is a bummer. If re-torquing them doesn't work doing a head gasket is no big deal, we can talk you through it.
Mark
Yorba Linda Cal.
  • ran429
13 Feb 2008 20:12
#194488
I will be re torking it this weekend after i warm it up a bit, i wont torque cold metal anymore.
I hate snapping bolts.
I hope it does the trick, if not i will be using you guys's help. I am just not to keen on going inside motors. Never done it before, always had my dad or Mechanic buddy do that stuff for me.
Guess i will be purchasing a new torque wrench soon.
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
13 Feb 2008 20:56
#194498
On that note it may be worth the time to pull each of the bolts you can out of their repective holes and "never sneezeing" them. Best of luck!;)
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • NickW900LTD
  • NickW900LTD's Avatar
  • Nick
14 Feb 2008 01:23
#194508
after having my head rebuilt I was scared to put the cams in ect....Im no mechanic by any means, grab a manual and study it, once you have done that you will feel more comfortable about doing the job!!!!
All my stuff is back together and running great!!!
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
  • BSKZ650
  • BSKZ650's Avatar
14 Feb 2008 04:51
#194521
Its not that hard, plus if you do have to go into it, you will care a lot more on how it goes back than the person who built it at the factory
77 ltd1000, current rider
76 kz900, just waiting
  • bemoore
  • bemoore's Avatar
14 Feb 2008 07:33
#194538
All torque specs I've seen are for cold bolts/nuts. You might want to break all the bolts loose on a hot engine, but do the torquing on a cold engine.
77 KZ650C1 w/Kerker 4-1
  • kawsakiman
  • kawsakiman's Avatar
14 Feb 2008 10:03
#194562
while your in there, why not change the valve springs and at least lap the valves in?
also gives you a chance to bench shim the head and get a real good look at the top of your pistons.
nothing to scary. like they said, we can talk you through it if you get stuck.
take some pictures along the way.
