Engine differences 1973 and 1974
  • 00.
  • 00.'s Avatar Topic Author
  • 1973 kawasaki z1
12 Feb 2008 23:26
#194320
Hi I'm restoring my 73 z1 and found there are a lot of engined diferences internaly and externally can any one tell me some of the differences as I have two engines that were taken a part and one is 74 and the other 73. The cover for the front chain sprokets are different one cover has the shifting numbers stamped on it and the other does not; one engine is black other not; one engine has a differnet base block and cylinder gasket. Is there any other differences and which engine has the shifting stamped on the front sproket cover. Plese let me know as I'm trying to restore everything to 73 specific. Thanks
1973 kawasaki z1
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Engine differences 1973 and 1974
13 Feb 2008 00:18
#194325
See my response in your other posting:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • wiredgeorge
  • wiredgeorge's Avatar
13 Feb 2008 05:26
#194362
There are several message boards around the world which focus only on the Z1, Z1A, Z1B and KZ900 (or Z900). These boards tend to have the serious restorers who can point out the small and somewhat obscure differences between models that allow correctness in a restoration project. I can help you with carburetor differences. There are very small differences in the carburetors for the early 73 models and later in the year models, for instance but if I were restoring a Z1 and needed help with this type detail, and I lived in the US, I would check out:
groups.msn.com/WorldwideZ1Z900Ownerscomm...homepage.msnw?&pps=k
