Copper Head Gaskets
- 1045
Copper Head Gaskets
11 Feb 2008 14:56
Anybody out there ever make their own copper head gasket??? If so, what thickness did you use, how did you cut the holes cleanly, and what grade of copper do you use???
1045
1045
1045
- bountyhunter
Re: Copper Head Gaskets
11 Feb 2008 15:23
No. I have never seen a head gasket that was solid copper. The ones I have seen are top and bottom copper layers over a compressible inside material that is sandwiched. The last one I got looked like it is some kind of fiberglas type of stuff in between the copper outside layers.
- StreetfighterKz
11 Feb 2008 15:57
Why not just buy one? Is this also going on a streetbike? If so you might have some top-end oiling leaks with a copper head gasket compared to a fiber one.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- racer54
11 Feb 2008 16:09
I agree with StreetfighterKz...if you are putting this on a streetbike, I would use a fiber head gasket. Copper head gaskets are best used on a cylinder that has been o-ringed. Copper just doesn't seal as good as a fiber unless you have the o-rings installed on the cylinder.
- 1045
