engine case sealant
  • kaw74z1
  • kaw74z1's Avatar Topic Author
  • 0 to 60 in 15 minutes.
engine case sealant
10 Feb 2008 15:47
#193844
Hi and thanks for the great info that I have received from you guys. My questions are I need to know the torque on a set of used APE cylinder studs and also what sealant do you recommend To use when assembling the engine cases of a kz 1000. Thanks
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
  • PLUMMEN
  • PLUMMEN's Avatar
Re: engine case sealant
10 Feb 2008 19:53
#193886
silicone or 3-bond;)
  • Dirtybiker
  • Dirtybiker's Avatar
10 Feb 2008 20:51
#193898
I like too use 3bond or this stuff
Aviation Form-A-Gasket® Sealant Liquid (3H)
problem with silicon is just hurneates out the sides and creates a poor seal. The 3bond and the aviation gasket sealants are easy too clean also. What i do is apply it too both surfaces and then to both sides of the gaskets.
I am told that they really do use it on air crafts... gotta be good stuff I suppose then.
Scott
  • Dirtybiker
10 Feb 2008 20:52
#193899
Scott
  • Dirtybiker
10 Feb 2008 20:52
#193900
Scott
  • Dirtybiker
10 Feb 2008 20:53
#193901
Scott
  • kaw74z1
10 Feb 2008 21:24
#193905
Hey, Thanks But I am Asking a question about sealing my engine cases Not a clutch cover! Thanks
  • bountyhunter
  • bountyhunter's Avatar
11 Feb 2008 10:27
#193965
If you have a Kawi/Yamaha dealer nearby, go there and ask their service guys. They told me that they use a special dedicated sealer that Yamaha sells to assemble their engine cases. I remember I passed on it because it was about $30/tube, but they swear by it. If it is something you never want to take apart, that is the right stuff.
  • MDawnz1
  • MDawnz1's Avatar
11 Feb 2008 11:34
#193991
I use "ThreeBond liquid gasket 1004"
Yamaha sells the same stuff except they call it
YamahaBond ,,,and it's NOT $30 unless your being ripped off.
Just about any motorcycle catalog place will have it in the tools section.
Its gray ,comes in a tube ,,,,,,,,
It just works.
Check the APE website for the stud specs.
1974 Z1a, still 903
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
11 Feb 2008 11:38
#193994
ape cyl studs go in at 40 ft lbs.use red locktite.yamabond seems to be popular for cases . if u use oem gaskets u should not need gasket glue. if u use aftermarket u will.
Post edited by: mark1122, at: 2008/02/11 14:40
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • bountyhunter
11 Feb 2008 14:12
#194025
It just works.
Like I said, that was the price at the Kawi dealer. So, it goes without saying that buying it there would be getting ripped off.....
If I go back to the dealer, I'll check and see what it is they are selling. I just remember a small tube of something that was about $25 plus tax.
Post edited by: bountyhunter, at: 2008/02/11 18:20
  • inline4
  • inline4's Avatar
11 Feb 2008 17:19
#194058
I use Yamabond, when I can find it.
The parts guys at a local Yamaha dealer told me they can't keep iit in stock....................................................................................................
'cause the H-D dealer keeps buying all of it.:laugh:
Don't know how serious the guy was but it makes sense to me!:lol:
