- Thank you received: 1
Barnett clutch adjustment?
- love2ride
- Ngati Tumatauenga
08 Feb 2008 13:17 #193499
by love2ride
Newport News, Va
2006 Ninja 250 - Commuter
1978 KZ1000 - Not even close to stock.
Barnett clutch adjustment? was created by love2ride
P/O did tell me that he had a Barnett clutch installed when having the KZ1000 restored.
It has always been slightly difficult to pull the clutch handle in. Like using those grip strengthening devices. Man after a ride thru traffic my forearm is burning.
Can this clutch be adjusted so that it will not be so hard to pull in? I thought maybe its the cable but its new. Only has a few hundred miles on it. It was hard for the p/o to pull in, and it hasnt gotten any easier.
Do I nede to deal with it or get an OEM clutch?
Newport News, Va
- BSKZ650
- Thank you received: 14
08 Feb 2008 13:23 #193501
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Barnett clutch adjustment?
that is the way the Barnetts are, you can change the springs back to stock and it will feel a lot better
- mariozappa
- Thank you received: 8
08 Feb 2008 13:23 #193502
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Barnett clutch adjustment?
I think you just need to change the springs back to stock/aftermarket stock.
I'm sure somebody else will chime in to verify.
1977 KZ650C1
- love2ride
- Ngati Tumatauenga
08 Feb 2008 13:43 #193505
by love2ride
Newport News, Va
Replied by love2ride on topic Barnett clutch adjustment?
So the stock springs are good to go with the Barnett?
Stock springs with high performance clutch is okay?
Thanks guys
Thanks guys
Newport News, Va
- Bluemeanie
08 Feb 2008 13:48 #193507
by Bluemeanie
Replied by Bluemeanie on topic Barnett clutch adjustment?
The springs are what gives you the lever feel. Light springs (factory) light pull, heavy springs, heavy pull. You may not realize the full potential of the Barrnet clutch with stock springs but the clutch is still better than factory. I've heard of a lot of drag racers using heavy duty clutch plates and stock springs.
- love2ride
- Ngati Tumatauenga
08 Feb 2008 13:51 #193508
by love2ride
Newport News, Va
Good to know.
I priced stock springs, they are not badly priced.
Thank you for the info.
Actually they are cheap. Z1 has a pack of 5 for $12.49
Post edited by: love2ride, at: 2008/02/08 16:59
Newport News, Va
- Lorcan
- Speed Loony
- Thank you received: 59
09 Feb 2008 02:22 #193567
by Lorcan
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Replied by Lorcan on topic Barnett clutch adjustment?
Real drag racers won't use anything other than stock plates.
760cc - 8.69@162mph
- Mark Wing
- Thank you received: 22
09 Feb 2008 09:25 #193603
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Barnett clutch adjustment?
Lorcan beat me to it. My buddy uses stock Kawasaki clutch plates in his 7 second Kawi drag bike.
Mark
Mark
Yorba Linda Cal.
- themachine
- Thank you received: 4
09 Feb 2008 10:47 #193615
by themachine
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
Replied by themachine on topic Barnett clutch adjustment?
i heard about the stock clutch plates being better on the wallet and the aftermarkets not helping worth a s***.
- loudhvx
- Thank you received: 1616
09 Feb 2008 18:08 #193686
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Barnett clutch adjustment?
love2ride wrote:
I called 3 reputable shops and they each said the same thing: "Throw away any aftermarket clutch and use genuine Kawasaki parts only." (These were not kaw dealers either. They were independent shops.) They were all very adamant about it too. This is after I swapped plates, disks and springs several times. Finally after putting in new OEM disks and springs, the clutch felt like brand new... very light and no hint of slippage.
The Kaw parts cost about 30% to 50% more, but after doing A/B comparisons, I would have been willing to pay well over 100% more.
Post edited by: loudhvx, at: 2008/02/09 21:10
I went through this. Aftermarket disks with stock springs slipped like crazy on my 550. The aftermarket springs were way too stiff to use in heavy traffic. (Your left arm would end up looking like Popeye's.)So the stock springs are good to go with the Barnett?
Thanks guys
1981 KZ550 D1 gpz.
Other links.
