goose exhaust
- NickW900LTD
- Nick
goose exhaust
07 Feb 2008 09:32
i have some 4-2 straight pipes i want to put on. They are stock exhaust pipes fom a kz1000 with no baffles. I want to know if it would hurt the motor to have them on. The carbs are jetted for a 4-1 header. I didnt know if a 4-2 open exhaust would need rejetting.
Nick
Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- Locozuna
Re: goose exhaust
07 Feb 2008 11:13
Any time you change the amount of air getting into the engine (ie = pods, stacks or airbox) or air getting out (ie = stock exhaust, 4 into 1, 4 into 2, baffles or unrestricted) you change the ratio and are subjected to variations of how the engine will run. This is seen also where people who have switched to pods will frequently experience throttle fluctuation's when passing vehicles or when being buffeted by cross winds. These things like a constant air flow ratio. Disrupt it and you might not like it. Change it and you may have to re-jet to find the optimal. Another thing to keep in mind is there a crossover equalization tube between the exhausts? This is frequently overlooked. My 900 breathes out through 2 and 2 with no crossover to equalize the back pressure between them. It adds a slight difficulty in dialing it in but nothing big. A 4 into 1 should be equalized if it is any good and a bit easier.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- NickW900LTD
- Nick
Re: goose exhaust
07 Feb 2008 11:19
the exhaust has an equalizer tube, if that makes a difference.
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
- Locozuna
Re: goose exhaust
07 Feb 2008 11:48
I kind of take it you are resistant to re-jetting. How much do you want to switch exhausts? If you are serious about switching go ahead you may get lucky. You may have to re-jet or you may be able to switch back. Nothing is irreversible or unfixable in this. Stock exhaust with stock airbox and filter should take stock jets. This is your control. Change 1 factor and you MAY get away with it but change two and you'll certain need to adjust. Do you know if she has been re-jetted already?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- NickW900LTD
- Nick
Re: goose exhaust
07 Feb 2008 14:23
The carbs have been totally rebuild and rejetted for pods and 4-1 header.
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: goose exhaust
07 Feb 2008 17:20
Why don't you just try it then see if it needs rejetted? It could be spot on or maybe just the clips need raised or lowered but no jetting changes. Trying to guess ahead of the mod is pretty hard to do. As far as hurting the engine, probably not as long as you see how it runs first then check the plugs for too rich or too lean. Personally I never liked the sound of stock 4 into 2's with the baffles out, tends to cut the top end too. Not knocking it if you like the sound so just do it and see if you think it needs jetting.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- Shoe48
- Live each day as it is your last
Re: goose exhaust
07 Feb 2008 18:04
KZ_Rage wrote:
I agree with you JimWhy don't you just try it then see if it needs rejetted? It could be spot on or maybe just the clips need raised or lowered but no jetting changes. Trying to guess ahead of the mod is pretty hard to do. As far as hurting the engine, probably not as long as you see how it runs first then check the plugs for too rich or too lean. Personally I never liked the sound of stock 4 into 2's with the baffles out, tends to cut the top end too. Not knocking it if you like the sound so just do it and see if you think it needs jetting.
- NickW900LTD
- Nick
Re: goose exhaust
07 Feb 2008 21:26
just tried it, its loud but its nice!!! Im gonna wait till the motor cools to check the plugs.
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
- bountyhunter
Re: goose exhaust
08 Feb 2008 10:20
NickW900LTD wrote:
They will also destroy your hearing in short order.
Post edited by: bountyhunter, at: 2008/02/08 13:23
I would guess straight pipes would run very lean.i have some 4-2 straight pipes i want to put on. They are stock exhaust pipes fom a kz1000 with no baffles. I want to know if it would hurt the motor to have them on.
- Gosling1
- Whats behind you is not important
Re: goose exhaust
08 Feb 2008 11:26
[qoute]They will also destroy your hearing in short order.<br><br>Post edited by: bountyhunter, at: 2008/02/08 13:23[/quote]
Fo sho. I ran my 1100 with 2 and 2 straight pipe for a while. It was loud and could give a headache. It was even louder than my 370 dirtbike with no baffles on the end of the expansion pipe.:evil:
1983 KZ1100A Shaftee box stock.
A herd of Bultacos to play in the dirt with. Arvada, Colorado
Kick it in the guts Berry
