Main stud torque
  • kaw74z1
  • kaw74z1's Avatar Topic Author
  • 0 to 60 in 15 minutes.
Main stud torque
06 Feb 2008 20:48
#193190
Hi, would someone help me out on this, I am installing a set of used APE main studs with nuts into a kz 1000. My question is what do I set the torque at? Thanks in advance
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Main stud torque
06 Feb 2008 21:16
#193195
on the stock bolts i believe its around 18' pounds with a little oil on the threads.i cant remember for studs but i usually run the studs themselves in reasonably tight then torque the nuts,i dont torue the studs themselves.maybe give Apejay a call;)
  • kaw74z1
07 Feb 2008 21:04
#193397
Hey Thanks, I guess ask the wrong question, The toque on the main nuts is what I need to know, They are APE used studs and nuts.also I need rigs for weisco 1075 pistons I think x rings. Help APE JAY. Thanks
  • PLUMMEN
  • PLUMMEN's Avatar
07 Feb 2008 21:52
#193402
found some old notes ,20'lbs ;)
  • APE Jay
  • APE Jay's Avatar
07 Feb 2008 22:19
#193405
Don't think X rings are available qanymore. Can you measure the thickness of the old rings?
www.aperaceparts.com/tech/mbskaw.html
Jay
  • kaw74z1
08 Feb 2008 14:23
#193515
Hi,I hope these measurements help This is the specs. on the 1075 wiesco piston's X rings , top ring is .38, second ring is 1.16 and the oil ring is .107 In metric they measure top .95 mm second ring is 1.16 mm and oil ring is 2.71 Also on top of the ring is stamped N100 Thanks
  • APE Jay
  • APE Jay's Avatar
08 Feb 2008 17:40
#193536
That is an XC ring. Currently available. We stock them.
Jay
Post edited by: APE Jay, at: 2008/02/08 20:40
  • kaw74z1
08 Feb 2008 22:35
#193557
Thanks Jay can you tell me the torque on the main studs an nuts these are used APE parts. Going to order rings very soon do you have a part number for the rings. Thanks
  • PLUMMEN
  • PLUMMEN's Avatar
09 Feb 2008 10:04
#193611
  • APE Jay
  • APE Jay's Avatar
09 Feb 2008 11:16
#193622
I posted a link above. We have a pretty good tech page on our site.
Jay
  • jordan172005
  • jordan172005's Avatar
12 Feb 2008 20:24
#194309
hmmm... for some reason I thought it was higher than 20... well today I put my kz650 together and they're tightened to 70ft/lbs... I guess I must be lucky that they held up lol.
