split collars too short
- NickW900LTD
- Nick
04 Feb 2008 09:55
The split collars im using will not butt up to the collar for the header im using. They are 1/2 inc long and i need about another 1/4 inch. Anyone have a spare set?
Nick
Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- 77KZ650
Re: split collars too short
05 Feb 2008 17:48
last resort, use extra exhaust gaskets to fill the gap
07 MDP Rookie of the Year
- Bluemeanie
05 Feb 2008 18:40
1/2 in long? Sounds way too short1 Using the collars that came with the bike? Been a long time but IIRC mine are about 1" to 1 1/4" long. Got pics?.....
- KZQ
- Administrator
05 Feb 2008 18:40
Sounds pretty strange! Here's what usually happens. An owner buys an aftermarket system and finds that the system won't bind up tight. The problem usually stems from the flanges on the exhaust system being too thin. The solution is to add a used gasket with a new gasket, It's worked for me.
kzcsi
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- BSKZ650
06 Feb 2008 04:59
what kind of header are you using?
77 ltd1000, current rider
76 kz900, just waiting
- krcrawford29
06 Feb 2008 19:56
Bluemeanie, do you know where you got your split collars???
Sorry to high jack the post, but i too have this problem. I noticed that the stock exhaust has about 1/2 inch collar welded to it. This is where the slightly over 1/2 inch split collars push up against, then snugging the header to its home. In the end you have a 1 to 1-1/4 inch split collar to fix the problem. For now I made some crappy washers/split collar extenders out of tinfoil and super glue, just so I can ride.
- NickW900LTD
- Nick
06 Feb 2008 20:53
im using an old Russ Collins header, i found some new split collars on ebay so im good to go as soon as they arrive.
Nick
Nick
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
- PLUMMEN
06 Feb 2008 21:18
ive seen shorter collars,i think they are for j-style head;)
- The Gringo
- ¡Usted no necesita otra motocicleta!
06 Feb 2008 22:28
krcrawford29 wrote:
I ran into this when I put an exhaust from a 2002 ZR7 on my 650 C-1 the collars from the 650 were too long. I needed the shorter ones like what is used on the 650H or the 750H. I just ordered new ones from Kawasaki as I recall they only cost like $3.00 each. I can't say for sure if the longer collars are still available you might try checking your friendly local Kawasaki dealer though.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Bluemeanie
10 Feb 2008 06:39
When I bought my Kerker back in '81, everything bolted up perfect with the stock collars that came with the bike. Of course this was way back when they made headers that fit perfect!
10 Feb 2008 07:08
An extra 2mm thickness may not be enough in this case, but here's Z1E's link suggesting an alternative to the oem Kaw copper gasket.
kazuki
kazuki
