Engine going weak when riding
- EasyRider1
1978 KZ650C
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- EasyRider1
1978 KZ650C
- The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- EasyRider1
in addition to that also check the fuel filter to make sure its clean and not starving for fuel
I must admit, I am still a little perplexed about the timing thing. I am going to check my manual and see if I can borrow a timing light but maybe there are some other things I could check in the meantime (besides the fuel filter, I'll check that too)?
1978 KZ650C
- BSKZ650
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
You don't sound like an idiot at all. Under the point cover on the right side you will find the timing advance unit attached to the right side of the crankshaft. There should be 2 screws holding this cover on. The easiest way to check this is with a timing light. With the engine running and the light hooked up, when you rev the engine you will see the timing mark on the advancer move as the engine gains rpms. If you don't have a light, try to find a buddy to borrow one from or possibly check with autozone (they have a program where they will loan you tools with a deposit). I hesitate to tell you to tear the points plate off and remove the advancer to verify it's condition since that is going to require you to reset the points and timing. Better to verify it first in case it is not stuck and it turns out to be something else.
FYI, the '81 440 has electronic ignition--no points.
West Linn, OR
- wiredgeorge
- Link14
- Thank you received: 6
The problems never showed up unless I was revving above 4500-5000 rpm's. Wired George could explain better, but I believe that's when the diaphram is supposed to lift the needle and open up the needle jet allowing more fuel to flow in the 1/2-full throttle range.
No lift - no fuel - depressing bogging sound.
Good luck!
- EasyRider1
A side note, when you replace the carb diaphraghm are you supposed to lube the sides of the slides?
Post edited by: EasyRider1, at: 2008/02/04 14:08
1978 KZ650C
- Link14
My guess is that the tolerances are so tight that anything that could increase the friction between the slide and the body should be avoided.
