cam help please!!
  • kaw74z1
  • kaw74z1's Avatar Topic Author
  • 0 to 60 in 15 minutes.
cam help please!!
01 Feb 2008 22:50
#192302
I had some one on a z site to give me cam specs but it was in German, So I translated it to English and I still cant read it. Please help me figure this out!! Here are the dates of the cam shaft:
- Hub: E/A= .360"= 9.144mm; -- Stroke: E / A = .360 "= 9.144mm;
- Steuerzeiten 266°; E 23/55 ; A 55/23 -- Tax times 266 ° E 23/55, 55/23 A
Gemessen bei .030" = 0.76mm Ventilspiel; Measured at .030 "= 0.76mm clearances;
- Ventiele sind bei Überschneidung bei OT .109"= 2.76mm offen; -- Ventiele may overlap in OT .109 "= 2.76mm open;
- Vetiêlspiel auf 0.1- 0.15mm einstellen; -- Vetiêlspiel to set 0.1-0.15mm;
- Lobcenter 106° -- Lobcenter 106 °
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
  • steell
  • steell's Avatar
Re: cam help please!!
02 Feb 2008 08:40
#192357
My best guess :)
Maximum valve lift, intake and exhaust
Intake/exhaust opening and closing times in degrees. I think E is intake and A is exhaust
Measured at .030 valve clearance
Little puzzled on this one
[/quote]
106 degrees lobe center :)
I'm sure someone will correct me if I'm wrong.
Post edited by: steell, at: 2008/02/02 11:41
