pistons
  • kaw74z1
  • kaw74z1's Avatar Topic Author
  • 0 to 60 in 15 minutes.
pistons
30 Jan 2008 21:02
#191920
Hi All, I have a set of after market pistons that I think are 1075. Can anyone of you guys help me out on the Manufacture of these pistons, In the center they are stamped 4024ps under that is the letters xc, On the right side of the top is h31b7 If anyone can help me out with this I would sure Thankful!BTW These are from a 1978 kz 1000
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
  • APE Jay
  • APE Jay's Avatar
Re: pistons
30 Jan 2008 22:33
#191928
Very old Wiseco. The XC is the ring style. Might want to measure them for taper. There should ne at least .002"
Jay
Post edited by: APE Jay, at: 2008/01/31 01:34
  • kaw74z1
Re: pistons
30 Jan 2008 22:57
#191932
Thanks Jay, Can I still get rings for these pistons? Also I have a set of cams that came with these pistons do you have a idea as to what duration and lift they are the numbers on them are CWC EP_14 also has I-5 and c2 on the ends of them. Thanks bunch"s
  • APE Jay
  • APE Jay's Avatar
Re: pistons
31 Jan 2008 12:58
#192025
Yes the XC rings are available. We stock them.
As for the cams, the CWC is the billet manufacturer, the EP14 is the billet part number.
The I 5 and C2 would be the markings that tell what cam grind it is, but I don't recognise them.
Jay
  • 77KZ650
  • 77KZ650's Avatar
Re: pistons
01 Feb 2008 22:21
#192296
you should be able to get the lift and duration with a mic and a degree kit
07 MDP Rookie of the Year
