mk11 crank
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
mk11 crank
29 Jan 2008 16:49
#191715
will a z1 or kz rotor and starter clutch fit a mk11 crank?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • racer54
  • racer54's Avatar
Re: mk11 crank
29 Jan 2008 18:08
#191728
I don't think so. The Z1, KZ900 and the KZ1000 cranks have a small end (22mm I think) while the MK11 has a larger crank end (25mm I think) although I was told a few KZ1000 cranks have the larger end, but not sure which models had them. My guess would be that if the crank has the rotor rotate INSIDE the alternator coils it is a small end while the big end cranks have the rotor on the outside of the coils (MK11 style).
  • mark1122
  • Keep twisting it
Re: mk11 crank
29 Jan 2008 18:17
#191732
Thanks Racer. you da man. man u get around fast. must be that racer green blood.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
