fast-rising revs
  • Rickman
  • Rickman's Avatar Topic Author
fast-rising revs
27 Jan 2008 16:30
#191322
Since the 1171 kit, When my bike is warm, it pings thru the low midrange 2.5-4000 rpm -- when you're in higher gear and open the throttle. It seems to me that before it warms up, it doesn't ping, but when I drive like that cold, somewhere in that range there's a spot where the revs can suddenly shoot up like I dunno, 1000 rpm in a real split second.. Does anyone know what I mean?
I'm still planning to get a dyna 2000 to address this, but as a relative newbie on my first bike, I'm curious if anyone knows what might be going on in my engine, or if I'm just imagining things.
thanks
Ricky
Edit, PS: Oh -- maybe my clutch is slipping?
Post edited by: Rickman, at: 2008/01/27 19:31
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
  • THE WIZARD
  • THE WIZARD's Avatar
Re: fast-rising revs
28 Jan 2008 03:12
#191384
Bigger Motor More Fuel,one size on pilot two on main.
  • Rickman
26 Mar 2008 21:23
#202409
I'd done the jets already, and now I've done the dyna2000 and it still does it so I'm thinking I need to raise the needle if I can find the right kind of washers.
26 Mar 2008 22:58 - 26 Mar 2008 23:07
#202420
Possible air leak? If not already done, would check to assure no air leak due to cracked carb holder, loose clamp, improper fitment of carb into holder, or otherwise. Effect could worsen with warming and coming off choke. Air leak could also result from faulty closure of choke plunger whereby the rubber seal at base of choke plunger fails to close off the separate air intake passage which provides air to the enrichener fuel mixture and is supposed to be blocked when the choke is off (i.e., choke plungers in down position).
Mixture too lean? Could also double-check setting of carb pilot adjustment screws.
Ignition timing? Would double-check (with strobe-type timing light) to assure correct setting and proper operation of advancer unit (if applicable).
As to clutch slipping -- would perform clutch push-rod adjustment per FSM (through access cap on engine sprocket cover). This is a independent adjustment, separate and apart from adjusting slack within the clutch cable. Lack of sufficient gap in the clutch push-rod can easily prevent the clutch plates from completely engaging (i.e., prevent the clutch plates from completely closing together).
Hoping for simple fixes. :cheer: Good Luck! :)
Last edit: 26 Mar 2008 23:07 by Patton.
  • The Milkman
  • The Milkman's Avatar
26 Mar 2008 22:59
#202421
thanks
Ricky
If you speed isn't picking up with the rpm's then yes your clutch is slipping. If it is pinging when it is warm, check the timing, and also check that the centrifugal timing is also working correctly.
  • nads.com
  • nads.com's Avatar
26 Mar 2008 23:13
#202422
thanks
Ricky If you feel vibration through the handlebars at 80mph, the timing is too advanced. U have to back the timing off after the piston kit or use premium fuel.
  • wiredgeorge
  • wiredgeorge's Avatar
27 Mar 2008 11:38
#202499
Sounds like an air leak in the enricher or pilot system. You might want to mention which carburetors are being used.
