almost done with head installation
- NickW900LTD
- Nick
26 Jan 2008 22:34
The torque wrench my friend let me borrow is 1/2 inch drive and I only have 1/4 sockets. I have the head on and some anti sieze on the studs and the nuts hand tightened, I numbered the nuts with a marker according to the manual. I also went ahead and put my RC header on and put the carbs back on, I didnt figure this would hurt anything even though the head wasnt torqued yet.
Im pretty confident about about putting the cams back in and at the same time im scared. But the more I study the shop manual the better I feel.
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- Mcdroid
- Gone Kwackers
Re: almost done with head installation
27 Jan 2008 02:14
Actually, if you have the Kawasaki factory shop manual, and follow the directions completely, and have all the correct tools, reassembly is pretty much foolproof. You have done several things out of sequence...e.g. attached your carbs and header. I understand you are getting anxious, but it is possible that by attaching those to the head before you torque it down properly, there may be a problem reaching the proper torque values for the head. I'm not saying there will be a problem, but why take a chance? You are almost there
Post edited by: Mcdroid, at: 2008/01/27 06:30
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mariozappa
27 Jan 2008 06:32The torque wrench my friend let me borrow is 1/2 inch drive and I only have 1/4 sockets
Surely your friend has the right size 1/2 socket if he has the torque wrench.
I can't remember. What is it, 17mm?
1977 KZ650C1
and the KZ650/KZ750 Conversion
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
27 Jan 2008 08:12
mariozappa wrote:
You should need a 14mm socket for the head nuts, and 10mm for the end bolts.
And I'd recommend using a 1/4" torque wrench for the end bolts as they require much less torque, and a 1/2 wrench may be not be sensitive enough at low torque.
Post edited by: Skyman, at: 2008/01/27 11:17
West Linn, OR
- modprod
27 Jan 2008 09:46
Skyman wrote:
[quote
And I'd recommend using a 1/4" torque wrench for the end bolts as they require much less torque, and a 1/2 wrench may be not be sensitive enough at low torque.<br><br>Post edited by: Skyman, at: 2008/01/27 11:17[/quote]
Yes, an "in lbs" torque wrench for the small 6mm bolts. Using "Ft lbs" is not the right way for those small bolts. Pipes and carbs do not get mounted until the head is on and torqued.
[quote
- bountyhunter
28 Jan 2008 11:35
Skyman wrote:
Ditto. On mine, the torque spec was 360 inch-pounds which is abouyt 30 ft-lbs. My small torque wrench (600 in-lb max) is much more accurate at 360 in-lb than my big wrench (150 ft-lbs max) is at 30 ft-lbs.
mariozappa wrote:I can't remember. What is it, 17mm?
