Nitrous experience? help, or advice?
  • jordan
  • jordan's Avatar Topic Author
26 Jan 2008 19:34
#191167
Just built a 1981 kz750 motor. Installed an 810 wiseco big-bore kit, gpz cams, and kz1000 strip/street clutch springs. I really hope to run this bike at the strip a few times this summer. I plan on buying the nitrous express nitrous system for 4-cylinder carbeurated bikes. I plan on using the smallest shot, 40 hp. Do you think my motor build could withstand the nitrous setup. Are there things I can do to make it run nitrous easier. Timing, plugs, anything? Oh, and timing should be easy, hava a dyna 2000 ignition on its way.
www.nitrousexpress.com/power_sports/60005P.htm
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Nitrous experience? help, or advice?
26 Jan 2008 21:31
#191192
id look into their progressive controller ,having your bike swap ends at 60 mph really takes the fun out of it!:P id also make sure you run an aftermarket petcock and a large enough fuel line and some carb tweaking to avoid leaning hr out when the nitrous hits;)
  • 77KZ650
  • 77KZ650's Avatar
01 Feb 2008 22:47
#192301
pull 2 degrees of timing to play it safe when the nitrous is activated. check your plugs after a run at minimum to see how its running, or get a data logger. innovate makes nice ones
07 MDP Rookie of the Year
