- Thank you received: 1
tune up
- squints
24 Jan 2008 16:17 #190879
by squints
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
tune up was created by squints
If I dropped my bike off at the shop (which I hope not too any time soon) and said "Give her a good tune-up," what would they do.
What type of thing would a shop do to my bike for a tune up? synch carbs, top off fluids, grease things that need to be greased... is there something more I'm missing?
what else would they check/do?
Upstate NY
- kzwolfsr
- Thank you received: 16
24 Jan 2008 17:12 #190892
by kzwolfsr
Original man of the Caribbean
Replied by kzwolfsr on topic tune up
Which bike. If it was the older 650 it would be spark plugs change oil and filter, change air filter check brake fluid and brake pads, grease up your swingarm if they knew about the zerk fitting there on the swing arm air up the tires and possibly redo your chain tension in the engine and lube your chain. I used to work at a bike service place, but never did anything, I just watchedOn you 1000 there is no zerk on the swingarm and the cam chain self adjusts and check air pressure on forks if you have that set up on yours also. I work on my own 2 bikes and you have the same combo as me so as I do for mine I would do for yours
- Bluemeanie
- Thank you received: 14
24 Jan 2008 17:17 #190893
by Bluemeanie
Replied by Bluemeanie on topic tune up
I've owned my bike for 28 years and am a mechanic. So I've never taken it to a shop but would think that you might have to be specific as to what you want done. Or better yet let them explain what a "tune up" consists of. Then add things as needed. Are there any members that live near you? We are all willing to help each other and save money too!
- Thank you received: 2829
24 Jan 2008 19:00 #190926
by 650ed
Replied by 650ed on topic tune up
Bluemeanie is right, have them provide a list BEFORE letting them touch it. I've done all my own tune-ups since my bike was new (April '77) and among other things I lube timing advancer, install new points & condensor (of course, check & adjust timing), plugs, carb synch, check valve clearances (this has remained unbelievably constant), replace or clean air and inline fuel filters, and adjust timing chain tensioner. I do this stuff roughly every 5,000 miles. I change the fork oil and brake fluid every 2 years. Other items such as lubing and/or adjusting drive chain, lubing swing arm, changing oil&filter, etc. I do more often. Once you've performed these maintenance tasks a couple times they become very simple and do not seem to be such a big deal. Get the correct Kawasaki Factory Service Manual for your specific model before you start. Ed
- squints
27 Jan 2008 09:11 #191254
by squints
Upstate NY
Replied by squints on topic tune up
oops the 1000 Im talking about.
With the exception of checking valves and synching carbs I have be doing everything mentioned so far. I just always thought there was more that I was missing. :silly:
Upstate NY
- hwms
27 Jan 2008 10:54 #191273
by hwms
Replied by hwms on topic tune up
Give you a bill for 650.00 bucks
- hwms
27 Jan 2008 10:55 #191274
by hwms
delete double post
Post edited by: hwms, at: 2008/01/27 13:56
- bountyhunter
- Thank you received: 337
28 Jan 2008 11:38 #191437
by bountyhunter
Replied by bountyhunter on topic tune up
squints wrote:
With instructions that vague, they will empty your wallet: probably oil, filter, plugs, valve adjust, clean/rebuild/sync carburetors for starters.If I dropped my bike off at the shop (which I hope not too any time soon) and said "Give her a good tune-up," what would they do.
