sparx battery eliminator any ever use one
- odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
- 76 LTD
- Thank you received: 1
- odl666
1979 gs750e
- bountyhunter
- Thank you received: 337
Had one on an old Triumph and it worked good.But anything is an improvement on the Lucas system.Lucas electric also builds refrigerators thats why people in europe drink hot beer.
His prowess with auto electrics is why every Brit refers to Lucas as "the Prince of darkness".
- loudhvx
- Thank you received: 1616
If the alternator uses a field coil, then it will need some sort of battery, however it can be just a small scooter battery.
The majority of KZ's have permanent magnet alternators. The most notable exceptions are the early (if not all)KZ400's and the 1977 KZ650.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Gra
1979 KZ650 - Under restoration
- loudhvx
Yes, otherwise you will get too much voltage to the capacitor (which is what a usual battery eliminator is.)Do you need to still have a rectifier / regulator if you have a battery eliminator??
Also if you do this, and the reg/rec has a brown wire to it, the brown wire must be hardwired to the capacitor. Normally the brown wire gets shut off when the bike is shut off. But that means the alternator is still running un-regulated until the motor actually comes to a stop. This means the alternator is putting out full power during the time the motor is turning and the bike is shut off. (This can happen anytime you are coasting in gear with the ignition off, but it also happens when you turn the motor off for a brief moment.) With a battery, this is not really an issue since a battery can act as a crude regulator. A capcitor does not. It will just get huge surge of voltage until it fails.
To prevent that, the brown wire must be hard wired to the capacitor.
There is no issue if the reg/rec does not have the brown wire and only has the positive-output and ground. I don't think the 79 650 has the brown wire.
1981 KZ550 D1 gpz.
Other links.
- Thank you received: 2829
Lucas - because gentlemen shouldn't be motoring about after dark anyway.
