it lives! KZ400-project
- primemover
20 Jan 2006 16:58
Hi All...
i suspect many people post subject lines like that when they get a project bike to turn over and idle...
figured i would not dissapoint!
Long and short:
pulled out the carbs (they were a mess!) and cleaned them up (and replaced some parts from an extra KZ305 carb set i had) and put them back in the bike today...
popped the gas tank back on and hit the button...
at first it did not do much, but then I remembered about the "pri" position on the petcock...
turned it to that (waited a few mins, even tried to drain float bowls - to get gas flowing - though nothing came out)...
then, hit the start buttom again...
BAMP! (in a good way!)....
she started right up and idled (little round) but "fine" (note: was producing some white exhaust but prob from some oil leak somewhere)...
not bad for a bike that sat for ~10 years (or more???)....
oh! I even shifted it into a couple of different gears (while on center stand).... odd though... seemed like it is:
3
N
2
1
book says:
5
4
3
2
N
1
though i cannot be sure.... appears to need some clutch/cable work too
I even tried to start it up with the "kick starter"...
LIKE A FREAK'N CHARM!!!
Brooommm, started right up... on ONE KICK!
damn! felt good!
so....
now it starts....
she goes up on the jack and I start the real work....
1st priority - rear wheel (sprocket, chain, new tire, alignment, check brakes, etc...)
2nd - front wheel (tire, alignment, brakes, etc...)
from there???
everything else (I guess)
thanks for all your help...
i'll be around (in the various forums now)...
- prime
Long and short:
3
N
2
1
book says:
5
4
3
2
N
1
damn! felt good!
so....
now it starts....
from there???
- prime
- KitNYC
Re: it lives! KZ400-project
20 Jan 2006 20:21
Congrats! I just got mine running yesterday.
Rough, but good enough to get to the gas station under its own power...
The ding in the front rim makes replacing that wheel my #1 priority, but I have cables to adjust & oil to change while I wait for the wheel...
-Kit
-Kit
- 50 bucks
21 Jan 2006 02:52
Hey ! Congrats, Prime ! Glad to hear it's running. :woohoo: Still gathering parts for mine. To darn cold up here to work on a bike in the garage. But come spring.....:evil:
- primemover
21 Jan 2006 06:39
yeah, we've had some real above ave temps in North East pst few weeks....
i guess there are some benefits of "global warming" (at least until the atlantic ocean is pounding at my front door - i'm ~15 miles from the coast so i have some time!)
- KevZ
21 Jan 2006 07:09
Congratulations, Primemover. Make sure and take lots of pictures of the progress. Good luck!
