Oil all over the ass end of the bike
- oldkaws4ever
- Have no regrets...... You only live once.
16 Jan 2008 21:26
I Just had the 74 Z1 900 out on the highway today, and i had it up over 100 for a couple of seconds to "clear the carbon out", when i got to my girlfriends house there was oil on the swing arm and muffler, it looked like it spit out a bit of oil from the airbox, does this sound right? I dunno what happened, when i came home later, i opened it up again and hit about 110, got home and the was no oil on the ass end of the bike.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
Re: Oil all over the ass end of the bike
16 Jan 2008 23:45
did you check the oil in motor?probably coming from crankcase vent.motor might be suffering some blow by,or might be over full.either way check your oil,it aint purdy when they run dry;)
- oldkaws4ever
17 Jan 2008 09:57
when i went to top the oil off the other day, i think i added a bit to much. Cause its never did this before. I went out and checked the oil, and its right between the site marks on the window.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- trippivot
17 Jan 2008 11:05
overfilled KZ engines will spill out at high revs
these roller engines are forgiving on a little bit lower oil level as long as you can see it in the window.
it probably got its own level set after 20-30 seconds at 8000 rpm..
how cold was the oil? did you get'er good and hot to the touch before riding it fast?
I overfilled a dry sump system once except I got about 3 qts too much in the tank and when the oil from inside the engine got pumping it all spilled over and I wrecked my bike. but that was a dry sump system that had a bad reverse flow check valve.
Post edited by: trippivot, at: 2008/01/17 14:14
- oldkaws4ever
17 Jan 2008 11:14
Thats what i kinda figured
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
17 Jan 2008 11:25
ya the engine was thourly warmed up before i left the house, i was on the highway for like 10 mins before i cranked it up
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- GregZ
17 Jan 2008 11:55
Hey oldkaws. Please get in touch with me.
mrgjanko@yahoo.com
mrgjanko@yahoo.com
