what size is starter hole on kz 650? 30mm??
- odl666
16 Jan 2008 16:26
does any one know if the starter plug will fit on a kz 650 from ape. thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- 78kz650guy
Re: what size is starter hole on kz 650? 30mm??
16 Jul 2015 16:00
I'm sure you've figured it out by now, but for future readers; no, the 30mm starter hole plug will NOT fit a kz650.
- baldy110
17 Jul 2015 08:19
If all you want to do is plug the hole just gut an old starter and bolt it back in.
