Liquid gasket on the valve cover?
  • Little B
  • Little B's Avatar Topic Author
15 Jan 2008 22:11
#189517
I noticed that the manual says to use liquid gasket on the rubber plugs but doesn't mention using it on the valve cover gasket itself.
Is there any reason NOT to use it all the way around before putting the cover back on?
1981 KZ750-H2 LTD
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Liquid gasket on the valve cover?
16 Jan 2008 00:41
#189523
You could use gasket sealer, except that every time you pulled the valve cover, you'd have to clean (= scrape) both the head and cover. The engine cover that comes off the most is the valve cover...so, by using sealer, you may be making work for yourself.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Little B
16 Jan 2008 04:51
#189528
Well that makes sense. Will the gasket alone keep the oil from leaking out there?
1981 KZ750-H2 LTD
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
16 Jan 2008 05:47
#189530
Use three bond same as honda and yamaha bond ,, works great and comes off easy if you should need to do that ,, it is the best for motorcycles , I have tried them all .. Really :)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
16 Jan 2008 05:58
#189532
The gasket alone should prevent leaks...but, as Shoe48 suggested, if you still have a leak, Threebond will greatly aid in cutting down that leak (I also use the product, but on other engine covers). The key is to use a new valve cover gasket every time (rephrased, don't reuse old gaskets) :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Little B
16 Jan 2008 06:33
#189541
cool, thanks.
Which one of these is recommended?
www.threebond.com/LGasket.html
1981 KZ750-H2 LTD
  • RonKZ650
  • RonKZ650's Avatar
16 Jan 2008 07:08
#189550
No need to ever use sealer on a gasket if you clean the surfaces good. The way I do it is put Yamabond #4 on the cam end plugs and just a little on top of each cam end plug out a little ways each way on the head. Bolt the cover on then next time it's removed all 4 corners are held in place and the gasket stays on the head. Never leaks even after many times off/on.
  • bountyhunter
  • bountyhunter's Avatar
16 Jan 2008 09:17
#189561
Theoretically, it will if both surfaces are clean and smooth.
On mine, I always use a thin line of black Ultra High temp RTV across the areas where the plugs are because they used to always leak oil if I didn't. On the flat metal-to-metal surfaces, gasket alone will usually work.
  • bountyhunter
16 Jan 2008 09:20
#189562
Depends. On mine, the problem is that across the plugs, the rubber surface the gasket is pushing down on is much softer than the aluminum so where the plugs are the gasket would develop a "step" down there.... and the edge of the step would always leak oil.
lately, I make my own gaskets out of thinner material (1/32") which reduces the step effect. I still use RTV across the tops of the plugs to keep them from leaking just in case.
