GPz_Aussie wrote:
Exhaust valve clearances are all good, couple of the inlets are pretty close tho, i hate shimming
Once set, they'll stay for a good long while.
IMO underbucket setup was overkill for those cams. I've run them in KZ motors using top shims and never had a problem. While at the same time I've seen Andrews 3x [which is supposed to be top shim friendly] puke shims through the cam cover....go figure:unsure:
