1978 ticking sound
  • cableman30
  • cableman30's Avatar Topic Author
1978 ticking sound
10 Jan 2008 19:30
#188645
thanks everyone, it was exhaust leak that was ticking, now that i think about it gor worse last oil change, yeah i have to remove the header to change the filter, anyway, i pulled it off tonite, those little copper gaskets are in terrrible shape, i couldnt buy any tonite, so i reinstalled and retightned, and i barely can hear the tick now, it used to tick really bad at a idle, i think if replace those copper gaskets it will be completely gone. whatda think????
thanks Ben
  • themachine
  • themachine's Avatar
Re: 1978 ticking sound
10 Jan 2008 21:23
#188673
that will fix it good.
when you change your oil run rotella diesle oil. ;)
thanks Ben
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
11 Jan 2008 17:57
#188773
I just got this tip for reusing the exhaust gaskets:
"Take a propane torch and heat them up RED HOT. Then put them in a bucket of ICE COLD water. They pop back into shape. It's worked for me many times."
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • 76 LTD
  • 76 LTD's Avatar
11 Jan 2008 18:04
#188777
Another tip(dont laugh it works)wrap the copper O ring in good high qulity aluminum foil and reinstall.
