KZ750 1976 - Start up Issues
  • Rodman2
  • Rodman2's Avatar Topic Author
  • Rodman2
08 Jan 2008 09:56
#188271
Good Day,
I am orginal owner of '76 KZ750 and am new to the world of forums.
Took my bike apart over the holidays to track down an electrical issue, including removal of my carbs.
Electrical issue was located & fixed. After re-assembly, I found I could literally stand on the kick start.
I removed the plugs and was able to move the kick start down by hand. Too much compression??
Could this be the result of butterfly values not being partially open or would it be seized exhaust ports [hope not].
Bike has not been started for 1 year and was stored in my garage [50 degrees] under a cover.
Rodman2
1976 - KZ750 - Stock
Original Owner - Oakville, Ontario
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: KZ750 1976 - Start up Issues
08 Jan 2008 10:06
#188272
Any Chance you were experiencing a hydraulic lock? Could there have been fuel in a cylinder?
Now that you've removed the plugs have you reinstalled them and tried again?
"Could this be the result of butterfly values not being partially open or would it be seized exhaust ports"
Both alternatives above are not likely considering that you've rotated the engine already by hand.
I've seen kick starters with worn shafts and/or bearings lock tooth on tooth before but not on Kaws.
kzcsi
Post edited by: KZCSI, at: 2008/01/08 13:11
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Rodman2
  • Rodman2
08 Jan 2008 11:48
#188278
Not sure what a hydraulic lock is. I did remove and reinstall the plugs twice with the same result.
- Plugs out results in easy [by hand] reaction
- Plugs in results in standing on the kick stand
The only engine parts that I removed during my electrical failure investigation were the Carb's.
I disassembled the Carb's [removed float bowls, top coversand carb-piston [only] to check for gas gumming - all was ok].
The carb-pistons have a chamfer [I'm guessing to react to the air flow] and I was wondering if this condition could be the result of me putting the piston in backward [meaing piston chamfer facing the opposite way]?
Rodman2
  • BSKZ650
  • BSKZ650's Avatar
08 Jan 2008 11:53
#188280
is it possible that you have the wrong plugs in it, ie, the reach is too long
77 ltd1000, current rider
76 kz900, just waiting
  • Rodman2
  • Rodman2
08 Jan 2008 11:59
#188281
Thanks but no.
The bike was working fine until I had the electrical failure [loose connector under the gas tank].
I took the plugs out, cleaned them and rechecked the gap and put the same ones back in.
Rodman2
08 Jan 2008 15:20
#188311
Try this - pull all but 1 plug, see if the kick start will rotate. Try this with each plug to see if a single cylinder is causing the problem. This might help you pinpoint the problem. Ed
  • Rodman2
  • Rodman2
08 Jan 2008 17:35
#188323
You mentioned Hydraulic lock?
After thinking more about the problem I remembered dropping some oil down the piston head through the sparker plug hole.
Could this result in a the hydraulic lock that you referenced?
Rodman2
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
08 Jan 2008 19:10
#188336
Have you tried the kick start while the plugs were out?
Never mind you already answered that.
Can't be a hydraulic lock if it's happening as you say.
kzcsi
Post edited by: KZCSI, at: 2008/01/08 22:12
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Rodman2
  • Rodman2
08 Jan 2008 19:13
#188338
Ok, ok,
I'm a happy camper. The bike is running like new.
When I got home from work I re-tried the kick start and it's movement had returned to normal.
I can only conclude that, as suggested by KZCSI that I had created a hydraulic lock by dropping oil down the cylinder and it took some time for the oil to drip past the piston rings.
Whew, bike sounds great.
Thanks for all your suggestions - great forum I'm gald that I joined your group.
Rodman2 - Over and out
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
08 Jan 2008 20:14
#188347
Rodman2 wrote:
...I can only conclude that, as suggested by KZCSI that I had created a hydraulic lock by dropping oil down the cylinder and it took some time for the oil to drip past the piston rings....
Sorry I'm late to the thread, but yeah, that was definately it.
I know because I did it. I added oul to the cyl as part of my winterizing a couple years ago, and then a nice stretch of weather came and I un-winterized it. I had barely but a couple tablespoons of oil in there, but it would not let the motor turn. Certainly, in hindsight, it makes perfect sense....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
