Kick starter shaft removal question
- galaxian
08 Jan 2008 08:56 #188264
by galaxian
1977 KZ1000A1, 1979 KZ650 C3
Kick starter shaft removal question was created by galaxian
Am I going to have to split cases or is there another way i can remove the entire shaft and gear? Maybe from the oil pan (i hope)??? On the Kawasaki site i can see the diagram but not in relation to the cases themselves.
- wiredgeorge
08 Jan 2008 13:33 #188295
by wiredgeorge
Replied by wiredgeorge on topic Kick starter shaft removal question
I can't say for sure on the 650 in your sig but for the 1000, you have to yank engine and split cases. The kicker shaft connects directly by a gear drive to 1st gear in the tranny.
- OnkelB
- Thank you received: 80
08 Jan 2008 14:56 #188309
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Kick starter shaft removal question
galaxian wrote:
On the 650 you will have to split the cases too - even though you can remove the kick start shaft bracket and collar from the outside the kick start ratchet is too big to pass between the output shaft and the bottom of the case and thereĀ“s also the kick start stopper plate and rear oil galley to consider. To get the kick starter shaft out it needs to be tilted like shown in the pic below. No way around it, sorry.
Post edited by: OnkelB, at: 2008/01/09 00:29
- 1982KZ1100D1
08 Jan 2008 18:38 #188329
by 1982KZ1100D1
Replied by 1982KZ1100D1 on topic Kick starter shaft removal question
Why would you want to remove the kick starter? I would LOVE to ADD one to my 82 1100. I remember the kick start got me out of a bind several times on my old 80 KZ1000.:blush:
- galaxian
09 Jan 2008 05:58 #188377
by galaxian
Replied by galaxian on topic Kick starter shaft removal question
Guys thanks for the info. yeah its for the 1000 and i want to remove it beacuse its not really needed. Sure once in a while i may kick it, but mostly i use the starter. Worst case bump start it.
