'81 KZ1000 CSR cam question
  • HookedOnKawi
  • HookedOnKawi's Avatar Topic Author
07 Jan 2008 18:24
#188189
Hey all! I just got myself an '81 KZ1000-M1 (CSR) a week ago. I can't leave well enough alone and found these cams from Orient Express.
www.orientexpress.com/Kawasaki/Standard/KZ+1000/Camshafts/
Do they apply to the CSR? If not, who carries cams for this model? Thanks!
  • steell
  • steell's Avatar
Re: '81 KZ1000 CSR cam question
08 Jan 2008 04:01
#188223
Any of the 900-1100 KZ cams will fit, you just need the appropriate cam chain sprockets (available from APE).
The J cams would be a cheap upgrade, the 83-84 GPz1100 cams would be a better upgrade, then you have a bunch of aftermarket choices.
The CSR has a mechanical tach so it has the tach drive gear on the exhaust cam, the J and K (Standard and LTD) have a electronic tach (as does the GPz1100) so no tach drive gear.
  • HookedOnKawi
08 Jan 2008 11:01
#188274
Is anything after '80 considered the "J" model engine (998), and if so, will any aftermarket part for the "J" model engine fit my CSR? Thanks again, Steell.
  • Skyman
  • Skyman's Avatar
08 Jan 2008 13:12
#188288
The CSR has a "J" engine. All 1000's from 81 on have this engine. So any parts for a J engine should fit yours.
West Linn, OR
  • Skyman
  • Skyman's Avatar
08 Jan 2008 13:14
#188289
Correction--ALMOST any part. As was mentioned above, not all "J"s come with tachgear-equipped cams.
Post edited by: Skyman, at: 2008/01/08 16:15
West Linn, OR
  • steell
  • steell's Avatar
08 Jan 2008 14:03
#188302
One more exception, the 81 KZ1000P cop bike used the 1015 motor, the Cop Bikes switched to the 998 J motor (actually a CSR motor) in 82. The Cop bikes used the J motor from 81 all the way up through 2005, keeping that motor in production for 25 years, something of a record for a Japanese bike motor I think.
APE has a good explanation of the differences on their website.
Post edited by: steell, at: 2008/01/08 17:06
  • HookedOnKawi
08 Jan 2008 18:25
#188326
OK, got it. Thanks all for the help.
