- Thank you received: 104
Starting a big block
- PLUMMEN
kinda like a diesel,good idea if you have the roomB)im suprised nobody mentioned adding a small second battery you can hide somewhere and go with a 24v starting circuit. really helps bike bikes start, especially when hot. the rest of the bike is still 12v....
for example on a zx12r that had a 1361 kit with about 13:1 compression ratio(pump gas) sometimes had trouble starting when hot. switched to 24v. problem solved. now hes running a 1427, over 16:1 compression ratio(c44 race gas) still starts fine....
- mark1122
- Keep twisting it
- Thank you received: 109
i just bought a mk11 crank and sent it in for a rebuild, new bearings true and weld.
i bought a used honda starter. it sounds like i may have the starting isue solved. if thats not enought i will try 24 volts.Thanks
i'm also going to try to add more suport on top of the main bearing suport plate.
i would love to hear an actual tep #, for normal running and hot and tooooo hot? i had an oven thermometer in the oil galery last summer on my 1135cc(just drilled a hole in the cap bolt and siliconed the thermometer in). it ran at about 180*f. When i ran hard it would go off the scale wich only went to 220*.i boght a proper gauge last week, but it doesnt have a outer cover.it was meant for a dash mount.i'll have to make something?thinking of rolling a cylinder up out of .010" brass shim stock and soldering a bottom round into it??
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
- Banned
- Thank you received: 58
I was ready to answer " Well you take the casting over to the milling machine....." :laugh: :laugh:
- PLUMMEN
- 77KZ650
- Thank you received: 7
haha nice one Jay, now get back to work on the prototype removable cylinder block/cases for the 14:woohoo: it is started right???:whistle:I thought from the title of this thread that he wanted to know how you start a big block.
I know Rob said you cant go with a big block like his 1317(on the psycho board) but you could make it available as stock, or 2 or 3 mm over right?
getting back on topic, theres room for a(second) battery under the tank on a 900/1000 frame above the coils. you dont need a big one.
07 MDP Rookie of the Year
- 77KZ650
- mark1122
- Keep twisting it
Nice try Jay.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 77KZ650
have any pics of your pan with the pipe mounted? i bet theres room for the pan to grow some.
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 77KZ650
you can use valve lapping compound on a piece of glass(not much else is that easy to find that flat or common) to shave down the sides of the pump to tighten up the clearance
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 77KZ650
