kz750 h3 question
- Nubs
kz750 h3 question
31 Dec 2007 07:31
Sorry I don't know if this is the right forum for this post. Any way I have a 82 kz750h3 and was wondering if it is possable to replace the motor with a kz900 motor? Also if so, any modufing needs to be done?
Any input would be helpfull
Nubs
Nubs
- themachine
Re: kz750 h3 question
01 Jan 2008 23:23
its not a bolt in, but it is possible to modify the mounts to fit a 900 motor in, if you have welding and cutting abilities.
you may have to take the engine out of the frame to adjust the valves.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- NickW900LTD
- Nick
02 Jan 2008 04:49
if you have to take the engine out to adjust the valves then to me its not worth it.
Nick
Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- trippivot
02 Jan 2008 10:50
no, don't waste your time. the frame forward down tubes are in the exhaust pipes way after you get the engine squared in there. you need to bend the frame or squish the exhaust. neither are a good solution
