82 kz1000 m2 won't turn over
  • flrcreations
  • flrcreations's Avatar Topic Author
Re: 82 kz1000 m2 won't turn over
31 Dec 2007 17:29
#187164
Got sidetracked awhile today and cleaned the garage before working on the bike again. Anyway.... 1 and 4 TDC (top dead center). Ignition again with T1 verticle and F at index. Cams in and square. 44 pins between in and out. Decides to take starter apart. Starter does not have carbon build up inside. 1/2" long brushes. Stator had some black residue built up so I cleaned that off. Still got nothing. Seems like the stater does not have enough to spin things fast to get it started. Anyway of a starter to go bad other than the stator or brushes? Should I dig into the engine deeper and see if anything is bound up? Even te most outlandish things will be considered....
  • Skyman
  • Skyman's Avatar
31 Dec 2007 18:14
#187168
flrcreations wrote:
My concern is that nothing moves but the ignition advance when I turn the ignition side with a 17mm socket.
This is the part that has me confused. Are you saying that when you turn the ignition side with a 17mm socket, the ignition turns, but the cams don't? Am I reading that wrong?
West Linn, OR
  • NickW900LTD
  • NickW900LTD's Avatar
  • Nick
31 Dec 2007 18:23
#187170
i never used the 17mm socket, i used the kick starter to turn motor.
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
  • flrcreations
31 Dec 2007 23:47
#187190
too new for a kick start, and yes, if I turn if from the ignition advance side (right side) the cams do not move. If I turn the alternator (left side) everything including cams and chain and crank and ignition moves accordingly. I cannot push start as it is only motor and rolling chassis, no gas tank. Yes it is getting gas into the cylinders and vacuums it up from the gas can on the floor. I put the can on the floor after flooding it by having it too high before. The only other thing I can think of doing is putting it on the center stand and pulling my other bike behind it, taking off the other fender, and trying a stationary rolling start by strapping the two together.
01 Jan 2008 08:31
#187207
flrcreations wrote:
... if I turn it from the ignition advance side (right side) the cams do not move. If I turn the alternator (left side) everything including cams and chain and crank and ignition moves accordingly....
When turning the alternator (left side) moves everything (including cams and chain and crank and ignition), does the #4 (far right) piston move? And how is such #4 piston movement evidenced?
While turning the alternator (left side) and moving everything (including cams and chain and crank and ignition), can the crankshaft end on the ignition side be held stationary without movement (while everything else is moving)?
A camchain sprocket is located in the middle of the crankshaft. If the crankshaft itself is intact, moving the crankshaft from either end also moves the camchain sprocket.
Thinking maybe the bolt and/or 17mm "nut" on ignition (righthand side) end of crankshaft are turning, but without turning the crankshaft. Perhaps threads on the bolt that screws into the end of the crankshaft on the ignition (right hand) are stripped. Or threads inside the crankshaft end are stripped. Or the 17mm "nut" is damaged so that it is not holding in place against the end of the crankshaft. Or the end of the crankshaft is damaged and preventing the 17mm "nut" from holding.
Am hoping the crankshaft itself is not damaged.
Good Luck! :)
  • flrcreations
04 Jan 2008 17:46
#187686
Checked things over a little closer on the ignition side last night. The 17mm is actually a nut that turns the disc of the timing. Inside of the nut is a 12mm bolt that tightens everything up. I tightened the 12mm bolt and now when I turn the 17mm bolt, everything (cams, crank, chain) turns. Should I TDC the pistons and loosen the 12mm bolt to turn the ignition advance or take the cams off and TDC the pistons, then the ignition, then the cams? The cams and pistons are on TDC sync right now.
  • themachine
  • themachine's Avatar
04 Jan 2008 22:28
#187720
if your having problems with the electric starter not being able to spin it over fast enought use the kicker!
and swap the black/green wires around on the coils to see if it starts.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • Skyman
  • Skyman's Avatar
04 Jan 2008 22:55
#187721
M2--"J" Engine = no kicker. :(
West Linn, OR
