82 kz1000 m2 won't turn over
- flrcreations
- The Milkman
- Thank you received: 194
- flrcreations
- Thank you received: 2098
... ignition is set to top dead center....
On earlier models without igniters, the F marks are used when setting ignition timing, (and T marks ignored). Plug should fire before piston reaches top dead center.
Post edited by: Patton, at: 2007/12/31 01:43
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
On earlier models without igniters, the F marks are used when setting ignition timing, (and T marks ignored). Plug should fire before piston reaches top dead center. <br><br>Post edited by: Patton, at: 2007/12/31 01:43
I have the same model (M2). According to the factory manual, timing is to be set while aligned at the T mark.
West Linn, OR
- flrcreations
- wiredgeorge
The concern here is is alignment of the cam shafts to ensure they are timed correctly. First, put the crankshaft at TDC by aligning the T mark with the mark on the case. Stick your finger or a pencil in the #4 plug hole and ensure that you can feel the top of your piston crown.
Pull the cam chain out on the front and install the exh cam with the arrow pointing to the front. Find the chain pin that lines up with the EX line on the exh cam and count this pin as ZERO and count 44 pins over. The IN line on the intake cam must align with the 44th pin. When you have the cams positioned correctly, at TDC (for #1 and #4) the notches on each camshaft end will point away from each other.
- kawtoy
- Thank you received: 6
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- flrcreations
- wiredgeorge
OK... since you do seem to have an idea on how to set the cam timing (couldn't tell that from earlier part of thread), look at the ignition wires going to the coils. That is, the wires from the connector to the IC Igniter box to coils. One is black and the other is green. The green is likely the 2/3 coil and black 1/4 coil. Check to ensure that the spark plug wires from 2/3 coil are going to the 2/3 plugs and same for 1/4 which should go to 1/4 plugs. What kind of ignition is on this thing? Is it a stock ignition or aftermarket?
