She's done : (
- kzdev1360
She's done : (
30 Dec 2007 14:30
Well i got her out today and she was running great. I just put on my new electronic ignition and that open V&H was singing, when i heard the rod start knocking and she seized and spurted a bunch of oil out of the breather. Im a broke 19 year old college student and i just dont have the money to fix it. I have a rediculous amount of time and a money, more time than money, and its just a big dissapointment and doesnt really make me mad, just sad i guess. Idk...my venting is over. This sucks.
2006 Gsxr 1000
1976 Kz900 LTD
1977 Kz650 (720 motor, andrews cams)
1976 Kz900 LTD
- kawtoy
Re: She's done : (
30 Dec 2007 14:37
That really sucks bro. What do you think happened? Must have been starved for oil for some reason. If it were just bearings or a sloppy rod then you would have heard them a long time ago. Are you going to fix, sell or part it out? Where are you located? Maybe someone here can give you hand fixing it or buy it from you.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- kawsakiman
Re: She's done : (
30 Dec 2007 14:45
i have a lower half i can donate to a good cause.
Like kawtoy said, update your signature so everyone here knows where you are located.
i'm sure there is a member near you who can offer a helping hand or parts or something.
- kzdev1360
Re: She's done : (
30 Dec 2007 14:46
Im for sure going to fix it. I have another bottom end in the garage that only has 7xxx on it. I think it just threw a rod bearing, got hot and finally just siezed up. After i let her cool she turned over so im almost positive it was a rod bearing. i was just trying to get home before she went. I have a Big Block 78 malibu i need to finish and thats what gets all of my money right now. so the kaw will be getting slowly done. It should be back on the road by summer.
2006 Gsxr 1000
1976 Kz900 LTD
1976 Kz900 LTD
- kzdev1360
Re: She's done : (
30 Dec 2007 14:50
double post...sorry.
Post edited by: kzdev1360, at: 2007/12/30 17:51
2006 Gsxr 1000
1976 Kz900 LTD
1976 Kz900 LTD
- jim_palmore
Re: She's done : (
30 Dec 2007 14:50
that does suck...
ENJOY LIFE,, THIS IS NOT A DRESS REHEARSAL.
1991 KZ1000P FROM COPPER TO CHOPPER. MY BADASS BOBBER
- GPzephyr
Re: She's done : (
30 Dec 2007 14:52
What a shame. I feel for you.
So it seized up. If I was you I'd strip the top end down, that won't cost anything and have a good look at what damage there is.
If it hasn't thrown the rod then you might be able to get it running on the cheap.
Find the cause of the seizure first. Could you get away with a new rod bearing.
Do you still have your old pistons at all? Perhaps they could be brought back into service with a cheap set of cylinders.
Dont give up just yet
1991, Zephyr 750. GPz750 turbo engine, 810cc, Garrett T25 turbo, GPz1100 throttle bodies, 310cc injectors, Power commander, Dyna coils, Lots more as well...
KB Saturn fitted with a stock GPz750 turbo engine. Loads to do on this project.
- kzdev1360
Re: She's done : (
30 Dec 2007 15:00
Yea, i dont feel like it tonight, and i have to work tomorrow but tuesday i will tear down the top end. that will be no problem. I am almost sure it is a rod bearing. But i have a whole other engine still all put together minus the top end so its not as bad as previously thought. If the cylinders are still in good shape i will use my current jugs and 720 pistons. Question, are the wrist pins press fit or floating, i havent ever looked. If they are floating then it makes it easier to change the pistons over. Im starting to find the bright side in all of this. Ill be ok. Thanks alot guys its great to know that i have support from people who share a common interest. I really think i might be in love with this motorcycle lol. i will never give up on it.
Post edited by: kzdev1360, at: 2007/12/30 18:09
2006 Gsxr 1000
1976 Kz900 LTD
1976 Kz900 LTD
- kawsakiman
Re: She's done : (
30 Dec 2007 15:48
they float.
just remove the circlips and the wrist pins just push out.
glad to hear you are keeping it.
- BSKZ650
Re: She's done : (
30 Dec 2007 16:06
bummer big time, glad to see you have a extra engine, I would pull the pan off of the donor and check the oil pump and the bottom end, dont want to have to do it twice
77 ltd1000, current rider
76 kz900, just waiting
- kzdev1360
Re: She's done : (
31 Dec 2007 07:54
lol yea, i ended up going out to the garage pulled the pan off the donor bottom end and scraped the gunk off the pickup screen, there wasnt a whole lot just a little dirt, and i just checked everything out and it looks good. Question, should i use my clutch from the current engine, because this bottom end hasnt been started in 12 years. It tunred over smooth as glass but it wasnt run.
2006 Gsxr 1000
1976 Kz900 LTD
1976 Kz900 LTD
- JMKZHI
Last edit: 03 Dec 2008 20:37 by JMKZHI.
