valve clearance article
  • wiredgeorge
  • wiredgeorge's Avatar Topic Author
19 Jan 2006 11:50
#18684
I put together and article and got it to Stein and he put it in the article section today. Just click on "article" from the top toolbar and don't use the pull down. I also put the KZ1000 valve stem shim fitting guide which I used when I set up the head. It work very well and only two shims were marginal and I changed them just to take the pictures in the article. Anyway, hope it helps somebody. It is for the 903cc/1015cc engines but should help everyone with shim over bucket maintenance chores.
