gpz1100 and j head ?
- School Teacher
27 Dec 2007 21:24
#1 ok guys i did search on the forum. from what i gather the j head and the gpz head(-the 81) are the same- as for mounting them on a kz bottom end.
#2 the diffence between the the j head and the gpz11 head is valve size? any thing else?
#3 can you fix the compression by going with mtc/wiseco high compression pistons?
#4 what is the compression if you go with stock(gpz) pistons and a spacer block?
thanks scott
thanks scott
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- Mcdroid
- Gone Kwackers
Re: gpz1100 and j head ?
28 Dec 2007 02:22
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- kano
- Not Another Bloody Limey!
28 Dec 2007 04:36
dont forget the gpz1100 was fuel injected so it has inlets for the injectors in the head but its easy to tap a hex bolt in there or some ppl fab a little blank plate.
wg told me a couple of days ago
"The stock compression on all my bikes is about 8.75"
hope this helps
hope this helps
