Do I need a Oil Cooler?
  • Oldwolf
  • Oldwolf's Avatar Topic Author
22 Dec 2007 06:58
#186039
Just wanted to get Members advice before I started collecting the parts. This will be for a 1105cc with 29mm carbs and Kerker. Whats the thinking on a Cooler and Thermostate setup, needed or not. Lockhart or OldKawman type setup. Ebay or where? Thanks
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
  • BSKZ650
  • BSKZ650's Avatar
Re: Do I need a Oil Cooler?
22 Dec 2007 09:36
#186055
I like oil coolers, but then being in Houston, the weather is warmer and it just makes sense to me to try and keep it cool as possible
77 ltd1000, current rider
76 kz900, just waiting
  • cottoncandyninja
  • cottoncandyninja's Avatar
22 Dec 2007 11:11
#186064
i dont think you can ever go wrong with using an oil cooler. especially when one of the benefits of a cooler is a cooler engine and pro longed engine life.
  • racer54
  • racer54's Avatar
22 Dec 2007 11:51
#186069
Where is a good place to get a thermostat for a system already on a bike. I've seen them on bikes but never knew where to get one if it didn't come in a kit witht he cooler.
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
22 Dec 2007 13:22
#186075
Lockhart has offered them (chrome or gloss black) for 20+ years IIRC, possibly longer.
Lockhart Oil Cooler Thermostats
I've seen other thermostat brands out there specifically designed (per their listing) for motorcycles, I just can't recall who offers them or how effective they are compared to the Lockhart thermostats. :dry:
Post edited by: RetroRiceRocketRider, at: 2007/12/22 16:25
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • themachine
  • themachine's Avatar
22 Dec 2007 23:27
#186117
anything not stock needs a cooler, especially if you abuse it and its warm out.
thermostats? like a no bleed off valve or something?
where can i find a bigger oil cooler, my 1100gpz one seems a tad small.
Post edited by: themachine, at: 2007/12/23 02:27
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • StreetfighterKz
  • StreetfighterKz's Avatar
26 Dec 2007 04:33
#186409
What CR are you planning on running? If its relatively low, like 10.25:1 then I don't believe its necessary. And with 1105cc you should still have air passages between your cylinder since you'll be running a stock block. If you get into higher CR's and live in a warmer climate then you'll most likely need one. You also don't want to cool the oil too much as that can also hurt your motor in the long run.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Oldwolf
26 Dec 2007 12:52
#186459
Thanks Doug. 10.25:1 is about as high I plan on ruuning at this time. Hot here in the South during the Summmer time.
