Exhaust header dimensions
  • Harris Racer
  • Topic Author
20 Dec 2007 03:08 #185808 by Harris Racer
Exhaust header dimensions was created by Harris Racer
Wonder if any of you guys can help me.
Do you know the standard internal diameter of the header pipes for the Z1000 / 1978?
My race engine will be 1100 with 33 smoothbores, 10.5 CR, soft race cams (0.39 lift), ported etc and I need to estimate a starting point for the new headers given the hoped for power increase!!!!
Better still anyone have schematic for a suitable race pipe I can fabricate or is it just easier for me to inport a Kerker etc into the UK.
Thanks in anticipation.
Post edited by: Harris Racer, at: 2007/12/20 08:43
  • Mcdroid
  • Gone Kwackers
20 Dec 2007 04:27 #185812 by Mcdroid
Replied by Mcdroid on topic Exhaust header dimensions
The inside diameter of each header pipe that came off one of my 1977 KZ1000's is 33mm. The pipe is aftermarket (MAC) but it should be the same for all pipes (including stock).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
20 Dec 2007 09:28 #185838 by trippivot
Replied by trippivot on topic Exhaust header dimensions
a good place to start with what you are building is 1.500" (38mm) inner diameter tube. primary lengths no shorter than 27.00" longer in length is ok and perfectly equal is a tough task. my 4 pipes go from 27 inches to 32 inches in length (2 bends ea.)into a 60mm collector inner diameter pipe and then to the megaphone or straight pipe
Post edited by: trippivot, at: 2007/12/20 13:05
  • larrycavan
25 Dec 2007 07:55 #186344 by larrycavan
Replied by larrycavan on topic Exhaust header dimensions
Thanks in anticipation.<br><br>Post edited by: Harris Racer, at: 2007/12/20 08:43
If you really want to build a pipe, PM me and I'll give you dimensions for your specific engine setup.
  • Harris Racer
  • Topic Author
07 Jan 2008 12:30 #188152 by Harris Racer
Replied by Harris Racer on topic Exhaust header dimensions
Hi Larrycavan
Have tried to email you, but not heard back yet. Please confirm if you have received e mail via pm or advise alternative email address. Thanks
07 Jan 2008 16:25 #188170 by jagrider
Replied by jagrider on topic Exhaust header dimensions
I have some pictures and specs on the a exhaust I had made and you can take a look at my bike, jagrider this work very well with out the mufflers. 4x2 clock drag race times 1/4 10:07:24 and mid 9s to. 16/40 front and rear gearing. The other one was a 4 tubes that was not weilded to the end pipe it had a open end of 3.5 this made at a machine shop good friend I use his shop a lot he lets come in at night and use the machines a lot of the fabrication I did.
Thanks for the post I was typing with 1 hand. Could not down load 2 pictures off the 4 x 1 exhaust pictures to big.
I you can email me at jagcompany@aol.com and can email you back with some pics, I'm not racing the kz any more just fun street riding
Or may delete 2 of my post kz bike pics so you can see the exhaust.
jagrider
Post edited by: jagrider, at: 2008/01/08 14:22
Post edited by: jagrider, at: 2008/01/08 14:40
Post edited by: jagrider, at: 2008/01/08 16:37
Loud pipes save lives.
07 Jan 2008 17:22 #188184 by Frank
Replied by Frank on topic Exhaust header dimensions
That last post makes no sense. sorry but you should fix it.
