dynojet kits
- jordan
dynojet kits
18 Dec 2007 20:41
I am assuming that i will need to rejet after my build is done. kz750, 810, gpz head/cams.
Was wondering if anyone has tried the dynojet kits? Did you have very good luck? A friend of mine tried the dynojet kit and ended up putting different carbs on because the ones with the dynojet kit ran like crap. He had k&n pods, and a 4 into 1. His bike only ran good wide open. At stop signs gas would pour out of his carbs, and riding in town was not easy. Was there something he just didn't do right?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- oldkaws4ever
- Have no regrets...... You only live once.
Re: dynojet kits
18 Dec 2007 22:18
i was wonderin the same thing about dynajet. I have a 1977 kz650 with a 710 kit, pods, 4 into 1 vance and hine pipe with no baffle
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- gpzrox
Re: dynojet kits
19 Dec 2007 03:17
I think that Wired will get in on this, but my shopping is done, so I have time.
I think you said it right the first time: Jet kits work, but only if the carbs are good and the kit is done right.
Case and point: My GPZ ran like a raped ape, but I have a friend that works carbs like Wired does, and had me bring in a set that I picked up on ebay or somewhere. I just wanted to see what was done and what the difference would be. How bad could a running set of carbs be?
See, I pulled my carbs off the raped ape and they looked worse that the set I got on ebay.
For the next two hours or so we polished, used special homemade tools, and worked the carbs all over. And what I suspected was true: just a quick jet job is a disaster on a 20+year old bike.
And now my raped ape is ALOT smoother, and starts alot faster.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- baldy110
Re: dynojet kits
19 Dec 2007 08:16
Don't waste your money on a "jet" kit. They comprise of extra jets and needles with instructions. what you are paying for really are the instructions in the kit. It's cheaper to go to the junk yard and buy jets then dial your bike in.
- trippivot
Re: dynojet kits
19 Dec 2007 13:20
I really suggest getting a complete jet kit!!
Especially if you have newer CV carbs that have nonadjustable needles (thanks E.P.A.) The modified taper of the new needles is different than stock, and adjustable grooves are the key to tunning for midrange and throttle response...
BUT if your carbs have adjustable needles all you need to do is swap the main jets and change the needle setting to get the balance right. older carbs are very tunable.
- Nubs
Re: dynojet kits
31 Dec 2007 08:37
I agree, I put a d/j stage 3 in my 750. After many ajustments with needle hight, finly got it tuned. And I have good response and top end now.
- kawtoy
Re: dynojet kits
31 Dec 2007 10:30
I had a stage kit in my 1000 and it ran great. That was with the stock carbs and I have since gone to 34mm and now 29 smoothbores. I got a new set for $50 on ebay about 4 years ago. Came with a free dyno run coupon. As mentiond above you carbs nees to be in very good shape, clean and tuned correctly. Just throwing some bigger jets at a bike will only hurt things unless it is done correctly.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- eel
Re: dynojet kits
31 Dec 2007 14:18
the jet kits from back inthe 80s were trash. i ordered a DJ kit and never even installed it.. The needles that it came with were EXACTLY the same as my stock needles, and the jet sizes.. well DJ uses their own jet sizing.. so try and borrow jets from someone at the race track.. well they all have K or Mikuni jets not DJ jets. Plus all the slide drilling and crap..
i got my bike running smoother and better top end by just changing the mains and putting in/removing the airfilter if the temperature changes. and YES I RACE WITH AN AIRBOX.
1984 GPz750
2007 ZX6R
53-Racing.com - My Website
My GPz
2007 ZX6R
My GPz
