cams- what am i lookiing at
  • School Teacher
  • School Teacher's Avatar Topic Author
18 Dec 2007 18:09
#185641
ok guys these are suppose to be j head cams but do i see a tach gear on them ? would that make them a set of csr cams? do j head cams have more lft than early kz cams? or am i seeing things? as i have seen pics of j head cams that look like they have a "blank" for a gear but its not cut.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • steell
  • steell's Avatar
Re: cams- what am i lookiing at
18 Dec 2007 22:12
#185670
See the round boss with grooves in it between the cam gear and the first lobe to the right on the intake cam? That's how you tell the difference between J, LTD, and CSR cams.
I know that's in the manual because that's where I read it when I was searching for J cams (because J cams have more lift and duration than LTD or CSR cams).
Got stung on eBay with a set of LTD cams that were supposed to be J cams, then lucked out and got the even better 83-84 GPz1100 cams.
Since that set has the tach drive gear, I'd say they are CSR cams.
Post edited by: steell, at: 2007/12/19 01:13
  • School Teacher
18 Dec 2007 22:45
#185672
the guy was trying to tell me they were j cams from a standard do you know if the gpz 900 water pumper cams work in the kz or not?
thanks again
Post edited by: School Teacher, at: 2007/12/19 01:45
1980 kz1000G1
  • APE Jay
  • APE Jay's Avatar
19 Dec 2007 00:00
#185674
thanks again<br><br>Post edited by: School Teacher, at: 2007/12/19 01:45
No they don't.
Jay
  • School Teacher
19 Dec 2007 11:55
#185728
thanks
1980 kz1000G1
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
19 Dec 2007 13:51
#185736
School Teacher, What do you teach?
I would get your hands on some 29mm smoothbores as you will notice a difference that you will no doubt like. I might actually sell the ones I have on my bike if I go 1327cc probably not but those are the hot set up for that bike stock or modified a bit.
79 LTD B3
  • School Teacher
15 Jan 2008 12:08
#189443
i realize this is late but im a sixth grade teacher
its funny we were writing paragraphs the other day guess what i wrote about? a kz900....starting them early hehe
yep i almost got a pair off CL the other day...but its hard when you come in second on CL
1980 kz1000G1
  • larrycavan
  • larrycavan's Avatar
15 Jan 2008 14:23
#189452
That's funny!;)
Right on the Money info on the stock cam ID method as well.
Look at the boss for grooves. Model designation is as follows.
J Standard Model
Intake - One Groove
Exhaust - No Groove
1000 K[LTD]
Intake & Exhaust - 2 Grooves
1000 M[CSR]
Intake - Two Grooves
Exhaust - Tach Gear
K&M were 10* less duration than the J
Post edited by: larrycavan, at: 2008/01/15 17:30
