Oil filter cup
  • jimmybon
  • jimmybon's Avatar Topic Author
Oil filter cup
16 Dec 2007 02:48
#185278
I have a dilemma with my zrx1200
I have a genuine Kwaka manual that shows in the exploded view the oil filter metal cup ((they call it a fence) that sits around the oil filter)), on the top of the filter.
It just so happens that I'v been involved with Z650/750s for 30 years and that the cup sits under the filter in all that type of engine up to zr750 02 and it's exactly the same filter and set up
I smell a rat
can anyone confirm if the the genuine manual is wrong, or duz it even matter
cheers
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Oil filter cup
16 Dec 2007 06:26
#185288
The "fence" keeps any larger stuff away from the filter so as not to clog it up. Can you scan that diagram so we can see it. Does not make sense?
  • oldcoldankles
  • oldcoldankles's Avatar
Re: Oil filter cup
16 Dec 2007 07:30
#185296
Good question jimmybon and one that has stumped all the experts here so far. My KZ550 sits under the filter but the manual and parts diagrams clearly show it on top of the filter for my KZ1000. My 1000 manual also shows a man installing it on top and the text states to remove the fence from the top of the filter for that bike.
Post edited by: oldcoldankles, at: 2007/12/17 09:40
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • jimmybon
Re: Oil filter cup
16 Dec 2007 11:44
#185323
this is the scan of the manual, the diagram shows it on top and the picture shows it on the bottom
So it really matter?
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • loudhvx
  • loudhvx's Avatar
Re: Oil filter cup
16 Dec 2007 11:53
#185324
That's an interesting dilemma. On the 550's and 650's I've worked on, the cup was on the bottom. And to throw more questions into it, the KZ400 uses the same oil filter setup, but it has no cup at all (at least the few I worked on didn't).
  • jimmybon
Re: Oil filter cup
17 Dec 2007 02:54
#185395
ok, seems like we need some engineering to work this out.
The cup "looks good" sitting under the filter
but,
If there was no cup used, then the oil would perhapes flow from the entrance hole in the oil filter chamber and though convection, flow mainly through the top half of the filter and through the top hole in the filter bolt. Put that one down to the "on top" argument.
If the cup was on top of the filter then it would deflect the oil toward the lower end of the filter and through convection, travel though the filter from the lower surface to the higher suface using more filter area, and then throgh the top hole in the bolt. hence better filtering and longer filter life.
The filter is also fitted with a bolt that has a ball and spring valve in the middle of it, oil also will travel under the filter into the bottom hole and back through the second hole into the filter chamber, but if the filter becomes clogged then the oil would flow UNDER the filter though the bottom hole and then through the valve (under pressure) up through the centre of the bolt directly into the engine. It appears to me that the cup would obstruct the space under the filter for this to happen.
It seems to add up to "ON TOP"
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • Bluemeanie
Re: Oil filter cup
17 Dec 2007 06:25
#185412
I understand everything above, but.... everyone here has it on the bottom and the scan shows the man holding it on the bottom. Call your local Kaw store and see what they say. I would put it on the bottom! (My
bike below)
  • jimmybon
Re: Oil filter cup
17 Dec 2007 21:32
#185539
thanks Blue, u might find that your cup is perferated and that could make differance as well as with my kz650 77.
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
