1980 kz650 gasket set fit a 1977 b-1??
- steveo_4192003
- 77kz650b-1
13 Dec 2007 13:20
just wanted to see if this gasket set will work for my 77 b-1
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- Bluemeanie
Re: 1980 kz650 gasket set fit a 1977 b-1??
13 Dec 2007 14:44
I'm pretty sure it will fit, I believe all the 650 motors were the same excert for external stuff like charging systems, engine covers, etc. You can check with Kawasaki.com to make sure!
Post edited by: Bluemeanie, at: 2007/12/13 17:45
- steveo_4192003
- 77kz650b-1
13 Dec 2007 14:58
thank you! i was pretty sure to, but just wanted to hear it for reassurance!!
- Bluemeanie
13 Dec 2007 16:26
The valve cover gasket won't work as the '80 has the smog cover, but everything else should work.
Actually it will work, just cut off the tabs for the extra holes!
Post edited by: Bluemeanie, at: 2007/12/13 19:28
