gear slip
  • Eddie68
  • Eddie68's Avatar Topic Author
gear slip
11 Dec 2007 14:01
#184591
My z650E1 slips out of first gear into neautral if I pull away quickly Does anyone know why this might be happening and what I can do about it?
Thank you
ed
  • JimatMilkyWay
  • JimatMilkyWay's Avatar
Re: gear slip
11 Dec 2007 19:46
#184648
Hi Mr Ed
I can welcome you to the forum, but I can not advise you on transmission issues, and that is in all likelihood what you are describing. I have never cracked a case, but I will probably give it a shot this year.
Again, welcome.
Jim@MilkyWay
  • Eddie68
Re: gear slip
12 Dec 2007 00:42
#184676
Thank's mate:cheer:
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: gear slip
13 Dec 2007 09:51
#184883
I would suspect that you have a bent shift fork. It's possible that if this has been going on for a long time the engagement dogs have been worn down.
Do you have a manual? If not you'll need one.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Eddie68
Re: gear slip
16 Dec 2007 00:48
#185273
hi
sounds like a tricky job - I only have the tune up manual, so I will try and get hold of a one -- any ideas where?
thank's
ed
  • Little B
  • Little B's Avatar
Re: gear slip
16 Dec 2007 02:57
#185279
thank's
ed
Yep, check here . If you'd like one cheaper, take a look on ebay.
1981 KZ750-H2 LTD
