- Thank you received: 2098
Re-tap plug hole from deep end
05 Dec 2007 11:57 #183864
by Patton
Re-tap plug hole from deep end was created by Patton
- JimatMilkyWay
- Thank you received: 12
05 Dec 2007 19:23 #183906
by JimatMilkyWay
Replied by JimatMilkyWay on topic Re-tap plug hole from deep end
Patton wrote:
I have no knowledge of anyone who ever used it, but I see no reason it won't work. Now, ___I KNOW FOR A FACT!!!___ that you are considering buying this to use on someone else's head. If "your friends" head is not too badly damaged and if you have the aptitude and are careful enough such that _you never need it for yourself_, then you should be able to use it to safely chase threads. The question I personally would like resolved before I pluncked down the denero, is how the wedge/ram is held into place once retracted to spread the tap.
Post edited by: JimatMilkyWay, at: 2007/12/05 22:25
You're on your own, kid.Have no personal experience with this Back-Tap tool, but here's a link for consideration.
Back-Tap
- Little B
- Thank you received: 3
05 Dec 2007 19:50 #183912
by Little B
1981 KZ750-H2 LTD
Replied by Little B on topic Re-tap plug hole from deep end
Looks like a cool tool Patton but I sure hope I never need to use it! :blink:
1981 KZ750-H2 LTD
- Night_Train01
06 Dec 2007 03:55 #183938
by Night_Train01
Replied by Night_Train01 on topic Re-tap plug hole from deep end
I just ordered one to clean up the threads on my Z1R project. I will know soon enough how it works....
I found this post from a VTX site I belong too.
www.vtxoa.com/forums/viewtopic.php?t=190...order=asc&highlight=
- loudhvx
- Thank you received: 1616
06 Dec 2007 08:48 #183970
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Re-tap plug hole from deep end
Never seen that tool before, but it looks like it should work. Very crafty.
1981 KZ550 D1 gpz.
Other links.
