While I'm in there...
- kzmason
03 Dec 2007 20:31
So, as seen in my other thread, I have my '77 1000 motor completely torn apart right now trying to find a mystery noise. What I want to know is, if there is anything I should do while I have the cases split. I will be removing and blocking of the kick starter.
Re: While I'm in there...
03 Dec 2007 20:39
Would consider a new cam chain and any other cam chain related parts not otherwise replaceable without splitting the cases.
- donthekawguy
03 Dec 2007 22:47
If your planning on keeping the motor pretty close to stock you could leave it alone. But if down the road you think you might get bored with it, you could have the crank done and put in some heavy duty studs and have the tranny back cut. That way you won't have to do a tear down again. All of those things should run about $500 but will give you piece of mind and make for quick and easy upgrades later on. If you don't think you will be going fopr bigger power, you should at least have the tranny done and of course a new cam chain.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- kzmason
- BSKZ650
05 Dec 2007 09:20
they back cut the gears so that they will not slip out of gear and give a more positive shift
77 ltd1000, current rider
76 kz900, just waiting
- kawsakiman
05 Dec 2007 12:29
install a welded 900 crank that is 14lbs lighter so it will rev quicker.
( oh and the cam chain)
- steell
05 Dec 2007 14:48
As you are rapidly discovering,
It can turn a simple valve lash adjustment on a 1000 into building a 1500cc fire breathing monster
And devour your bank account in the process :woohoo:
is the most expensive phrase in this hobbyWhile I'm in there...
- rdgrnr
05 Dec 2007 19:52
or it started as a "Carb Cleaning":pinch:
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- kawsakiman
05 Dec 2007 20:30
rdgrnr wrote:
ain't that the truth!
almost 2 years and 3k later, my 650 " just needed rings"
i told everyone we need a 12 step program for motorcycles!
now i want a 550 tranny for the 650 so i have 6 speeds.
damm you steell! :woohoo:
- coppertales
06 Dec 2007 13:22
Yeah, put in a new cam chain. Also, replace your starter clutch rollers and springs. Install new valve oil seals and at least lap your valves to check that the seats are good.......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- CoreyClough
- GPz550 Addiction
07 Dec 2007 01:32
Don't even ask me how much I have into my 615 big bore kit. While waiting for the machine work to be done last year, I've replaced all the wheel, steering, and rear suspension bearings, and then bought another parts bike. I'm now teetering on rebuilding the complete bottom end, or installing everything I've bought in a 12,000 mile short block. Why not? Almost everything else is new on my '85 GPz550. Where do I sign up for the 12 Step Program?
"Hello. My name is Corey, and I'm a While-You're-In-There-Aholic".
:S
:dry: :whistle: :ohmy:
Post edited by: CoreyClough, at: 2007/12/07 04:33
:S
'85 GPz550(ZX550-A2)
- kzmason
07 Dec 2007 07:23
yeah, where do I sign up for the 12 step? The cam chain is new, I am lapping in the vavles, and installing new seals. If I knew that it was going to run once I put it back together (which I don't, see
this thread
) I would be all about throwing cash and trick parts at it, having it powder coated, and some many other things. But, I just can't justify too many extras until I know it runs right.
