Engine VIN Location
- EasyRider1
Engine VIN Location
03 Dec 2007 11:10
The title says it all. I can't seem to find the VIN on my KZ440 engine. Where is it?
1978 KZ650C
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Engine VIN Location
03 Dec 2007 11:41
It should be stamped on the engine cases above the clutch cover and just below the right carb.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- EasyRider1
03 Dec 2007 16:00
Would that be on the left side of the bike? There is a little stamped metal plate there that has numbers but it starts with KZ440 which is the model number and didn't match my other VIN number so I assumed that wasn't it. Maybe it is not original or I am looking in the wrong spot.
Post edited by: EasyRider1, at: 2007/12/03 19:13
1978 KZ650C
- steell
03 Dec 2007 16:26
Look on the head stock (steering stem) right behind the headlight, that's where the VIN number is, the number on the engine is the model and serial number of the engine.
- EasyRider1
03 Dec 2007 17:21
steell wrote:
Oh so motorcycles don't have the VIN on the engine block as well? It's just on the front stem?
1978 KZ650C
- The Gringo
03 Dec 2007 18:51
Sorry, I thought you were trying to find your engine number which is different than the VIN#. The engine # will be found where I described on the right side of the cases when you are sitting on the bike. The VIN# is as Steell said, on the headstock.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- steell
03 Dec 2007 19:56
Does any vehicle have the VIN on the engine block? I've never seen any, but I haven't seen everything.
- EasyRider1
03 Dec 2007 20:04
steell wrote:
I thought cars did. Maybe I just imagined that.
1978 KZ650C
- ibsen22000
03 Dec 2007 22:42
The engine, and the frame number(VIN) are not a matching number on the 440. The pic below shows where they are located on the 400 twins. On the 440 the frame number are located on the right hand side of the headstock
Post edited by: ibsen22000, at: 2007/12/04 01:55
