- Thank you received: 3
How to remove a Tach Bushing-Meter Gear?
- Little B
01 Dec 2007 20:57 #183451
by Little B
1981 KZ750-H2 LTD
How to remove a Tach Bushing-Meter Gear? was created by Little B
I'm trying to fix several oil leaks and need to take out the Tach Bushing-Meter Gear. (Part # 92087-010) The problem is, no matter how many times I turn the thing counter clockwise, it won't come out. Why would that be and how to I get around the problem?
After I turned it counter clockwise several times, I remembered that I was supposed to line up the timeing marks on the crankshaft first. :blush: So, once I remembered, I did that then continued to try and remove the meter gear.
BTW: It seems like that thing needs a 20mm socket to get it out. However, I didn't see any 20mm sockets at the store at all. It always jumped from 19 to 21. Whats up with that?
Any ideas guys/gals?
1981 KZ750-H2 LTD
- The Milkman
- Thank you received: 194
01 Dec 2007 22:21 #183455
by The Milkman
Replied by The Milkman on topic How to remove a Tach Bushing-Meter Gear?
For some reason I can't even find your model,,, 81 750 H2 in the Kaw parts diagrams!!!!!
- Little B
02 Dec 2007 00:24 #183461
by Little B
1981 KZ750-H2 LTD
Replied by Little B on topic How to remove a Tach Bushing-Meter Gear?
The Milkman wrote:
Took me a while the first time too. Here is the direct link to the parts diagram for my bike: 1981 KZ750-H2
In case the link doesn't work, just select the year '1981' and click 'continue'.
That brings up the list of bikes. Mine is the one towards the bottom that says "1981 0740 LTD Street Bikes 750 LTD-4".
The image you're looking for is: Diagram # 32 "Cylinder Head Cover KZ750-H2/H3"
1981 KZ750-H2 LTD
- The Milkman
02 Dec 2007 07:29 #183494
by The Milkman
From the looks of the parts diagram, it isn't screwed into the cover, the locking plate holds it in. It just pulls out, and turning while pulling helps. Try putting some lubricant where it joins the cover. The seal or gunk may just be hanging it up and holding it from coming out.
- Little B
02 Dec 2007 16:20 #183549
by Little B
1981 KZ750-H2 LTD
That did it, thanks Milkman!
1981 KZ750-H2 LTD
