Loud tick sound
- CptEDIV
Loud tick sound
27 Nov 2007 10:24
When I run my bike in the morning while cold, or damp from dew, or after a rain, during acceleration it'll make a loud tick from I think under the gas tank.. almost sounds like a tiny backfire or air blowing out of a tiny hole real fast. It seems like it lacks in performance after it gets a little wet. The coils are new-used and have no cracks or dings in them... What should I check for? Thanks
-Ed
-Ed
1979 KZ 650 D2 \"Midnight\" blue.
Re: Loud tick sound
27 Nov 2007 11:54
Could try water mist spray over spark wires and caps with engine running in a dark garage. Maybe get a free fireworks show.
- martijn
Re: Loud tick sound
27 Nov 2007 11:54
tick or ringing? and since when? could be big valve lash, broken piston rings, big end play, pinging or just a bad connection from high tension lead to plug cap. I´m sure there are a dozen more suggestions....:blink:
- CptEDIV
Re: Loud tick sound
28 Nov 2007 06:22
Its a loud tick tick noise, but not consistant at all, and its been doing it since it rained two nights ago. Valves clearance was set about 4 months ago. Doesn't seem to lack performance and gets less frequent as the bike warms up.
-Ed
-Ed
Re: Loud tick sound
28 Nov 2007 09:34
Thinking electrical leakage between coil and spark plug due to deterioration and/or cracking in spark plug wires and/or spark plug wire caps. Problem is worse under damp conditions. Heat from running tends to dry things out which may lessen the problem.
Check list:
Connection of plug wire to coil;
Integrity of plug wire;
Connection of plug wire to cap;
Integrity of cap;
Ohm readings between #1/4 caps;
Ohm readings between #2/3 caps;
Connection of cap to plug.
If plug wires are replaceable, here's a good choice that come equipped with caps already affixed.
plug wires
If plug wires are built into the coils, a special splicer may be required to install the new plug wires.
splicer
I use a little dilectric grease where the plug wire connects into the coil (Dyna coils and wires), thinking it helps repel moisture and inhibit corrosion, but some very well-informed others recommend against this.
Good luck!
Post edited by: Patton, at: 2007/11/28 12:35
Check list:
Integrity of cap;
plug wires
splicer
Good luck!
- fishybass
Re: Loud tick sound
28 Nov 2007 18:00
I agree with Patton. All indications are spark plug wires. Try spraying water on them when it's dark.
I had a similar problem with my VW. In that case the noise came from my ignition coil arcing.
Could the stator be arcing? I don't know about stators.
- CptEDIV
Re: Loud tick sound
29 Nov 2007 06:37
I pulled the plugs out and looked at em, they were a light red color? I pulled the plugs out of the carbs and let the fuel drain it, it had a reddish tint. I guess I was getting oil in the gas? I checked the oil level, it had too much, so I dumped some out. Could this cause that kind of sound? Haven't started it, ran out of gas... But I'll see tonight. Thanks for the help,
-Ed
-Ed
Re: Loud tick sound
29 Nov 2007 10:55
CptEDIV wrote:
...getting oil in the gas? -- doubtful. But didn't hurt to drain the float bowls, and might have flushed out some loose crud.
I checked the oil level, it had too much, so I dumped some out -- did it smell like gas? Gas intrusion into crankcase can result in serious engine damage. Would give crankcase oil the sniff test. If any doubt about being clean fresh oil, would change both oil and filter. And disconnect fuel supply to carbs and do not run engine until any such problem is corrected.
Could this cause that kind of sound? -- nope. The sound described is likely a spark leak.
...ran out of gas -- some gas might have migrated into the crankcase.
Good Luck! And don't forget about the water mist test in dark garage.
-Ed
