need help mounting my exhaust
- genesis
also, what is the proper way to mount the can to the header. I assume it should be welded, but can I get some sort of clamp to keep the exhaust from coming back out the cracks until I decide if I want to keep this can or not?
- rstnick
- Thank you received: 377
Lots of pipes and cans are clamped together. As long as the two are a good fit/compatable size with no gaps, clamping tightly should do the trick.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- genesis
- Thank you received: 2098
Just got my 4-1 brandless exhaust mounted on my 78 650 ...header went on fine, but the can is off from the stock mount by about 1/2 inch. what should I use to make a mount. I was thinking of getting a strip of steel, or some other metal and just drilling the bolt holes to make a sort of mount. any ideas or suggestions? also, what is the proper way to mount the can to the header. I assume it should be welded, but can I get some sort of clamp to keep the exhaust from coming back out the cracks until I decide if I want to keep this can or not?
Using a rubber isolator mount to affix can to hanger helps eliminate vibration transfer from can to bike frame. I've used then forever with great success. Available in various sizes. Here's an example.
Probably best not to weld, as welding eliminates ability to make exact fitment adjustments when installing. And if chrome, ruins the finish. Wouldn't use any sealer either. Small leaks usually self-seal after running a few miles.
Good luck!
- The Milkman
- Thank you received: 194
