Kz 400 Compression Test
- Shoey949
23 Nov 2007 12:51
Hey,
I have a 1978 Kz400 w/ 10,000 miles on it and it has been burning a good amount of oil. I ran a compression test with the carbs wide open and the engine warm, here's what I got.
Dry:
Left: 160psi
Right 180psi
Wet:
Left 225psi
Right:255 psi
Not sure exactly how to interpret the results. I haven't adjusted the valves yet since there a real pain. With that being said what conclusions if any can be made from these results?
Thanks,
Nate
Dry:
Left: 160psi
Right 180psi
Wet:
Left 225psi
Right:255 psi
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- loudhvx
Re: Kz 400 Compression Test
23 Nov 2007 13:13
Bad rings are indicated by the large increase in compression, but it seems way too high, actually. Is it possible you added too much oil? Too much and the combustion chamber volume will decrease causing artificially high compression.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Shoey949
23 Nov 2007 13:42
I think it was 3 cc's of oil in each cylinder. Wouldn't bad rings also cause a low reading in the dry test. The manual gives 142-156psi as "new" values with a minimum of 107psi.
Post edited by: Shoey949, at: 2007/11/23 16:44
Grand Rapids, MI
Grand Rapids, MI
- Bluemeanie
23 Nov 2007 14:01
Your compression rings might be ok but the oil rings may not be. Sure it's burning oil and not leaking? Could have some bad valve stem seals also, does it seem to burn more when started after sitting?, especially over night?
- Shoey949
23 Nov 2007 17:33
defintely burning oil, I can't say I've noticed any real patterns since it's actually my dad's bike.
Grand Rapids, MI
Grand Rapids, MI
- loudhvx
23 Nov 2007 18:56
Shoey949 wrote:
Yeah 3 cc's may be too much. Yes bad rings would give low readings dry. I should have mentioned the dry readings seemed ok. I was just blinded by the 255!
It should only need a drop or two to wet the rings.
180 is excellent. 160 is only roughly 10% lower than the 180. Perhaps a valve-clearance check should be done, and an adjusment may bring up the 160 cylinder.
The other source of burning oil is through the valve-guides. New valve guides are a big job, but you might get away with just replacing the seals.
Post edited by: loudhvx, at: 2007/11/23 22:02
1981 KZ550 D1 gpz.
Other links.
Other links.
- themachine
23 Nov 2007 22:53
if its 180psi you'll be needing some octane boost if its a pent head.
looks like your comp tester is fubar,if it has the possibility of making 255 you could run it on diesle
:silly:
Post edited by: themachine, at: 2007/11/24 01:57
:silly:
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- Shoey949
24 Nov 2007 09:32
Lou,
Have already got the head pulled so where part way there. As far as guides go would just involve replacing them?
-Nate
-Nate
Grand Rapids, MI
Grand Rapids, MI
- loudhvx
24 Nov 2007 11:00
I've never had to replace the guides. Someone here would probably know how... or better yet post a question on Ivar's KZ400 forum:
www.armbell.com/kz400/index.php?sid=c35c...fcc2365&mforum=kz400
That would be the best place for 400 twin specifics.
Also, the gpz 550's have 180 to 190 psi compression. They run on pump gas. I have one that has all four cylinders around 200 psi. That one needs octane boost. (But, I believe smaller cylinders typically can handle more compression without knock problems.)
1981 KZ550 D1 gpz.
Other links.
Other links.
- MDawnz1
24 Nov 2007 21:22
My 2 cents worth .
Borrow or buy a different gauge .
Something looks and sounds funny with your #'s .
I have to wonder how that engine can even spin over with #'s like that .
1974 Z1a, still 903
- loudhvx
24 Nov 2007 22:20
Since the head is off, did the 180 cylinder have a lot of carbon buildup? (Yeah I just re-read your post that 156 is a "new" reading.) That could explain the high reading. And there is the possibility that the gauge is off, as was mentioned.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Shoey949
25 Nov 2007 10:11
yeah the 180 cylinder had a lot more carbon build-up then the 160 one.
Grand Rapids, MI
Grand Rapids, MI
