Timing a 1980 550 LTD
- TheDevilZX
20 Nov 2007 20:23
So I realized that the timing on my 550 is advanced too far, and is igniting at an inappropriate moment, backfiring and setting fire inside of my airbox, this is bad.
The bike runs, spudders, but runs. I have no idea how to time this thing it is much different than the points i was dealing with on my 77 650-C, anyone with advice on this matter? I dont have the means to get a hold of a manual at the moment, so pictures if anyone has them, mostly advice, is very much appreciated!
- jjdwoodman
- Live free, or die.
Re: Timing a 1980 550 LTD
21 Nov 2007 00:04
Hey, Man!
Don't forget I've got a running 550 over here that we can look at for a reference.
You can retard the timing by loosening the backer plates and rotating the whole backer clockwise similar to how you would on a 650 even though there's no points there. You should have some marks though, and there's an e-book floating around here for that somewhere, I think.
You also might double check to see that your plug wires are not crossed anywhere.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- BSKZ650
21 Nov 2007 06:02
I think you might want to check the valves also, they may be tight
77 ltd1000, current rider
76 kz900, just waiting
- loudhvx
21 Nov 2007 11:50
There isn't really any way to adjust the timing. The timing plate is not slotted for adjustment. It's usually close enough that the timing plate won't make much difference.
However, there could be a problem with the advancer mechanism. Take it apart and clean it. Check the springs. Lightly lube it.
Make sure to note how it comes apart. It can go back together either of two ways. Only one way is correct. If the rotor is installed 180 degrees out, the bike will only backfire and not run.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
